For the latest stable version, please use Spring AMQP 3.2.5! |
Changes in 1.4 Since 1.3
@RabbitListener
Annotation
POJO listeners can be annotated with @RabbitListener
, enabled by @EnableRabbit
or <rabbit:annotation-driven />
Spring Framework 4.1 is required for this feature.
See Annotation-driven Listener Endpoints for more information.
RabbitMessagingTemplate
Added
A new RabbitMessagingTemplate
lets you interact with RabbitMQ by using spring-messaging
Message
instances.
Internally, it uses the RabbitTemplate
, which you can configure as normal.
See Messaging Integration for more information.
Listener Container missingQueuesFatal
Attribute
1.3.5 introduced the missingQueuesFatal
property on the SimpleMessageListenerContainer
This is now available on the listener container namespace element.
See Message Listener Container Configuration.
RabbitTemplate ConfirmCallback
Interface
The confirm
method on this interface has an additional parameter called cause
When available, this parameter contains the reason for a negative acknowledgement (nack).
See Correlated Publisher Confirms and Returns.
RabbitConnectionFactoryBean
Added
creates the underlying RabbitMQ ConnectionFactory
used by the CachingConnectionFactory
This enables configuration of SSL options using Spring’s dependency injection.
See [connection-factory].
Using CachingConnectionFactory
The CachingConnectionFactory
now lets the connectionTimeout
be set as a property or as an attribute in the namespace.
It sets the property on the underlying RabbitMQ ConnectionFactory
Log Appender
The Logback org.springframework.amqp.rabbit.logback.AmqpAppender
has been introduced.
It provides options similar to org.springframework.amqp.rabbit.log4j.AmqpAppender
For more information, see the JavaDoc of these classes.
The Log4j AmqpAppender
now supports the deliveryMode
property (PERSISTENT
or NON_PERSISTENT
, default: PERSISTENT
Previously, all log4j messages were PERSISTENT
The appender also supports modification of the Message
before sending — allowing, for example, the addition of custom headers.
Subclasses should override the postProcessMessageBeforeSend()
Listener Queues
The listener container now, by default, redeclares any missing queues during startup.
A new auto-declare
attribute has been added to the <rabbit:listener-container>
to prevent these re-declarations.
See auto-delete
Queues.
RabbitTemplate
: mandatory
and connectionFactorySelector
Expressions
The mandatoryExpression
, sendConnectionFactorySelectorExpression
, and receiveConnectionFactorySelectorExpression
SpEL Expression`s properties have been added to RabbitTemplate
is used to evaluate a mandatory
boolean value against each request message when a ReturnCallback
is in use.
The sendConnectionFactorySelectorExpression
are used when an AbstractRoutingConnectionFactory
is provided, to determine the lookupKey
for the target ConnectionFactory
at runtime on each AMQP protocol interaction operation.
See [routing-connection-factory].
Listeners and the Routing Connection Factory
You can configure a SimpleMessageListenerContainer
with a routing connection factory to enable connection selection based on the queue names.
RabbitTemplate
: RecoveryCallback
Option
The recoveryCallback
property has been added for use in the retryTemplate.execute()
See Adding Retry Capabilities.
MessageConversionException
Change
This exception is now a subclass of AmqpException
Consider the following code:
try {
template.convertAndSend("thing1", "thing2", "cat");
catch (AmqpException e) {
catch (MessageConversionException e) {
The second catch block is no longer reachable and needs to be moved above the catch-all AmqpException
catch block.
RabbitMQ 3.4 Compatibility
Spring AMQP is now compatible with the RabbitMQ 3.4, including direct reply-to. See Compatibility and RabbitMQ Direct reply-to for more information.
ContentTypeDelegatingMessageConverter
Added
The ContentTypeDelegatingMessageConverter
has been introduced to select the MessageConverter
to use, based on the contentType
property in the MessageProperties
See Message Converters for more information.
