For the latest stable version, please use Spring AMQP 3.2.5! |
Changes in 2.4 Since 2.3
This section describes the changes between version 2.3 and version 2.4. See Change History for changes in previous versions.
@RabbitListener
Changes
MessageProperties
is now available for argument matching.
See Annotated Endpoint Method Signature for more information.
RabbitAdmin
Changes
A new property recoverManualDeclarations
allows recovery of manually declared queues/exchanges/bindings.
See Recovering Auto-Delete Declarations for more information.
Remoting Support
Support remoting using Spring Framework’s RMI support is deprecated and will be removed in 3.0. See Spring Remoting with AMQP for more information.
