For the latest stable version, please use Spring AMQP 3.2.5! |
Asynchronous @RabbitListener
Return Types
@RabbitListener
(and @RabbitHandler
) methods can be specified with asynchronous return types CompletableFuture<?>
and Mono<?>
, letting the reply be sent asynchronously.
ListenableFuture<?>
is no longer supported; it has been deprecated by Spring Framework.
The listener container factory must be configured with AcknowledgeMode.MANUAL so that the consumer thread will not ack the message; instead, the asynchronous completion will ack or nack the message when the async operation completes.
When the async result is completed with an error, whether the message is requeued or not depends on the exception type thrown, the container configuration, and the container error handler.
By default, the message will be requeued, unless the container’s defaultRequeueRejected property is set to false (it is true by default).
If the async result is completed with an AmqpRejectAndDontRequeueException , the message will not be requeued.
If the container’s defaultRequeueRejected property is false , you can override that by setting the future’s exception to a ImmediateRequeueException and the message will be requeued.
If some exception occurs within the listener method that prevents creation of the async result object, you MUST catch that exception and return an appropriate return object that will cause the message to be acknowledged or requeued.
Starting with versions 2.2.21, 2.3.13, 2.4.1, the AcknowledgeMode
will be automatically set the MANUAL
when async return types are detected.
In addition, incoming messages with fatal exceptions will be negatively acknowledged individually, previously any prior unacknowledged message were also negatively acknowledged.
Starting with version 3.0.5, the @RabbitListener
(and @RabbitHandler
) methods can be marked with Kotlin suspend
and the whole handling process and reply producing (optional) happens on respective Kotlin coroutine.
All the mentioned rules about AcknowledgeMode.MANUAL
are still apply.
The org.jetbrains.kotlinx:kotlinx-coroutines-reactor
dependency must be present in classpath to allow suspend
function invocations.
Also starting with version 3.0.5, if a RabbitListenerErrorHandler
is configured on a listener with an async return type (including Kotlin suspend functions), the error handler is invoked after a failure.
See Handling Exceptions for more information about this error handler and its purpose.
