For the latest stable version, please use Spring AMQP 3.2.5!spring-doc.cn
Consumer Tags
You can provide a strategy to generate consumer tags. By default, the consumer tag is generated by the broker. The following listing shows the ConsumerTagStrategy interface definition:spring-doc.cn
public interface ConsumerTagStrategy {
    String createConsumerTag(String queue);
The queue is made available so that it can (optionally) be used in the tag.spring-doc.cn
