For the latest stable version, please use Spring AMQP 3.2.5! |
@Repeatable
@RabbitListener
Starting with version 1.6, the @RabbitListener
annotation is marked with @Repeatable
This means that the annotation can appear on the same annotated element (method or class) multiple times.
In this case, a separate listener container is created for each annotation, each of which invokes the same listener
Repeatable annotations can be used with Java 8 or above.
