For the latest stable version, please use Spring AMQP 3.2.5! |
Multi-method Listeners
Starting with version 1.5.0, you can specify the @RabbitListener
annotation at the class level.
Together with the new @RabbitHandler
annotation, this lets a single listener invoke different methods, based on
the payload type of the incoming message.
This is best described using an example:
@RabbitListener(id="multi", queues = "someQueue")
@SendTo("my.reply.queue")
public class MultiListenerBean {
@RabbitHandler
public String thing2(Thing2 thing2) {
@RabbitHandler
public String cat(Cat cat) {
@RabbitHandler
public String hat(@Header("amqp_receivedRoutingKey") String rk, @Payload Hat hat) {
@RabbitHandler(isDefault = true)
public String defaultMethod(Object object) {
In this case, the individual @RabbitHandler
methods are invoked if the converted payload is a Thing2
, a Cat
, or a Hat
You should understand that the system must be able to identify a unique method based on the payload type.
The type is checked for assignability to a single parameter that has no annotations or that is annotated with the @Payload
annotation.
Notice that the same method signatures apply, as discussed in the method-level @RabbitListener
(described earlier).
Starting with version 2.0.3, a @RabbitHandler
method can be designated as the default method, which is invoked if there is no match on other methods.
At most, one method can be so designated.
@RabbitHandler is intended only for processing message payloads after conversion, if you wish to receive the unconverted raw Message object, you must use @RabbitListener on the method, not the class.
