This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
Settings
Built-in emulation uses terminal width 80 and height 24 by default. Changing dimensions is useful if the output would span multiple lines and you don’t want to handle those cases in a tests.spring-doc.cn
These settings can be changed using properties spring.shell.test.terminal-width or spring.shell.test.terminal-height.spring-doc.cn
@ShellTest(properties = {
	"spring.shell.test.terminal-width=120",
	"spring.shell.test.terminal-height=40"
class ShellSettingsSample {}
ShellTest annotation have fields terminalWidth and terminalHeight which can also be used to change dimensions.spring-doc.cn
@ShellTest(terminalWidth = 120, terminalHeight = 40)
