This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
@ExceptionResolver
@ShellComponent classes can have @ExceptionResolver methods to handle exceptions from component methods. These are meant for annotated methods.spring-doc.cn
The exception may match against a top-level exception being propagated (e.g. a direct IOException being thrown) or against a nested cause within a wrapper exception (e.g. an IOException wrapped inside an IllegalStateException). This can match at arbitrary cause levels.spring-doc.cn
For matching exception types, preferably declare the target exception as a method argument, as the preceding example(s) shows. When multiple exception methods match, a root exception match is generally preferred to a cause exception match. More specifically, the ExceptionDepthComparator is used to sort exceptions based on their depth from the thrown exception type.spring-doc.cn
Alternatively, the annotation declaration may narrow the exception types to match, as the following example shows:spring-doc.cn
@ExceptionResolver({ RuntimeException.class })
CommandHandlingResult errorHandler(Exception e) {
	// Exception would be type of RuntimeException,
	// optionally do something with it
	return CommandHandlingResult.of("Hi, handled exception\n", 42);
@ExceptionResolver
CommandHandlingResult errorHandler(RuntimeException e) {
	return CommandHandlingResult.of("Hi, handled custom exception\n", 42);
@ExceptionResolver can also return String which is used as an output to console. You can use @ExitCode annotation to define return code.spring-doc.cn
@ExceptionResolver
@ExitCode(code = 5)
String errorHandler(Exception e) {
	return "Hi, handled exception";
@ExceptionResolver with void return type is automatically handled as handled exception. You can then also define @ExitCode and use Terminal if you need to write something into the console:spring-doc.cn
@ExceptionResolver
@ExitCode(code = 5)
void errorHandler(Exception e, Terminal terminal) {
	PrintWriter writer = terminal.writer();
	String msg =  "Hi, handled exception " + e.toString();
	writer.println(msg);
	writer.flush();
Method Arguments
@ExceptionResolver methods support the following arguments:spring-doc.cn
Method argument Description
Exception typespring-doc.cn
For access to the raised exception. This is any type of Exception or Throwable.spring-doc.cn
Terminalspring-doc.cn
For access to underlying JLine terminal to i.e. get its terminal writer.spring-doc.cn
Return Values
@ExceptionResolver methods support the following return values:spring-doc.cn
Return value Description
Stringspring-doc.cn
Plain text to return to a shell. Exit code 1 is used in this case.spring-doc.cn
CommandHandlingResultspring-doc.cn
Plain CommandHandlingResult having message and exit code.spring-doc.cn
voidspring-doc.cn
A method with a void return type is considered to have fully handled the exception. Usually you would define Terminal as a method argument and write response using terminal writer from it. As exception is fully handled, Exit code 0 is used in this case.spring-doc.cn
