This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
Hidden Command
It is possible to hide a command which is convenient in cases where it is not yet ready for prime time, or is meant for debugging purposes or you have any other reason you don’t want to advertise its presence.spring-doc.cn
A hidden command can be executed if you know it and its options. It is effectively removed from:spring-doc.cn
Below is an example of how to define hidden command. It shows available builder methods to define hidden state.spring-doc.cn
CommandRegistration commandRegistration() {
	return CommandRegistration.builder()
		.command("mycommand")
		// define as hidden
		.hidden()
		// can be defined via a flag (false)
		.hidden(false)
		// can be defined via a flag (true)
		.hidden(true)
Defining hidden commands is not supported with annotation based configuration
