This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
Testing
Testing CLI application is difficult due to various reasons:spring-doc.cn
  • There are differences between OS’s.spring-doc.cn
  • Within the same OS there may be different shell implementations in use.spring-doc.cn
  • What goes into a shell and comes out from a shell may be totally different from what you see in the shell itself due to invisible control characters.spring-doc.cn
  • The shell may feel synchronous but most likely it is not, meaning when something is written into it, you can’t assume next update in it is not final.spring-doc.cn
Testing support is currently under development and will be unstable for various parts.
Section Summary
