This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
TerminalUI
TerminalUI is a main implementation to drive ui execution logic.spring-doc.cn
Create TerminalUI
You can build TerminalUI manually but recommended way is to use TerminalUIBuilder build is autoconfigured for you and will set needed services.spring-doc.cn
@Autowired
TerminalUIBuilder builder;
void sample() {
	TerminalUI ui = builder.build();
	// do something with ui
Configuring Views
TerminalUI has a helper method configure(View) which can be used to set needed integrations into eventloop and other services.spring-doc.cn
TerminalUI ui;
void sample() {
	BoxView view = new BoxView();
	ui.configure(view);
Running UI Loop
Running TerminalUI execution loop is a blocking operation. You’re going to need a way to exit from a loop, for example Exiting App.spring-doc.cn
TerminalUI ui;
void sample() {
	ui.run();
Exiting App
If you want to exit from an app using normal CTRL-Q key combination listen events and request interrupt.spring-doc.cn
@Autowired
Terminal terminal;
void sample() {
	TerminalUI ui = new TerminalUI(terminal);
	ui.configure(view);
	ui.setRoot(view, true);
	EventLoop eventLoop = ui.getEventLoop();
	eventLoop.keyEvents()
		.subscribe(event -> {
			if (event.getPlainKey() == Key.q && event.hasCtrl()) {
				eventLoop.dispatch(ShellMessageBuilder.ofInterrupt());
	ui.run();
Modal View
TerminalUI supports having one active modal view. Modal view is placed on top of all other views and takes all input events.spring-doc.cn
TerminalUI ui;
void sample() {
	DialogView dialog = new DialogView();
	// set modal
	ui.setModal(dialog);
	// clear modal
	ui.setModal(null);
As views should not directly know anything about TerminalUi and interface ViewService exposes modal related functions.
