This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
Shell Context
The ShellContext interface gives access to a currently running shell context. You can use it to get access to a generic shell options.spring-doc.cn
InteractionMode is telling if shell is running on a non-interactive or interactive mode.spring-doc.cn
InteractionMode interactionMode = ctx.getInteractionMode();
Pty is telling if current terminal has a pty features which not a case when output is piped into file or if terminal is run in a ci system.spring-doc.cn
boolean hasPty = ctx.hasPty();
