This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
Legacy Annotation
When you use the standard API, methods on beans are turned into executable commands, provided that:spring-doc.cn
  • The bean class bears the @ShellComponent annotation. (This is used to restrict the set of beans that are considered.)spring-doc.cn
  • The method bears the @ShellMethod annotation.spring-doc.cn
The @ShellComponent is a stereotype annotation that is itself meta-annotated with @Component. As a result, you can use it in addition to the filtering mechanism to declare beans (for example, by using @ComponentScan).spring-doc.cn
You can customize the name of the created bean by using the value attribute of the annotation.spring-doc.cn
@ShellComponent
static class MyCommands {
	@ShellMethod
	public void mycommand() {
The only required attribute of the @ShellMethod annotation is its value attribute, which should have a short, one-sentence, description of what the command does. This lets your users get consistent help about your commands without having to leave the shell (see Help).spring-doc.cn
The description of your command should be short — no more than one or two sentences. For better consistency, it should start with a capital letter and end with a period.
By default, you need not specify the key for your command (that is, the word(s) that should be used to invoke it in the shell). The name of the method is used as the command key, turning camelCase names into dashed, gnu-style, names (for example, sayHello() becomes say-hello).spring-doc.cn
You can, however, explicitly set the command key, by using the key attribute of the annotation:spring-doc.cn
@ShellMethod(value = "Add numbers.", key = "sum")
public int add(int a, int b) {
	return a + b;
The key attribute accepts multiple values. If you set multiple keys for a single method, the command is registered with those different aliases.
The command key can contain pretty much any character, including spaces. When coming up with names though, keep in mind that consistency is often appreciated by users. That is, you should avoid mixing dashed-names with spaced names and other inconsistencies.
