This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Shell 3.4.0!spring-doc.cn
String Input
The string input component asks a user for simple text input, optionally masking values if the content contains something sensitive. The following listing shows an example:spring-doc.cn
@ShellComponent
public class ComponentCommands extends AbstractShellComponent {
	@ShellMethod(key = "component string", value = "String input", group = "Components")
	public String stringInput(boolean mask) {
		StringInput component = new StringInput(getTerminal(), "Enter value", "myvalue");
		component.setResourceLoader(getResourceLoader());
		component.setTemplateExecutor(getTemplateExecutor());
		if (mask) {
			component.setMaskCharacter('*');
		StringInputContext context = component.run(StringInputContext.empty());
		return "Got value " + context.getResultValue();
The following screencast shows typical output from a string input component:spring-doc.cn
The context object is StringInputContext. The following table lists its context variables:spring-doc.cn
Table 1. StringInputContext Template Variables
Key Description
defaultValuespring-doc.cn
The default value, if set. Otherwise, null.spring-doc.cn
maskedInputspring-doc.cn
The masked input valuespring-doc.cn
maskedResultValuespring-doc.cn
The masked result valuespring-doc.cn
maskCharacterspring-doc.cn
The mask character, if set. Otherwise, null.spring-doc.cn
hasMaskCharacterspring-doc.cn
true if a mask character is set. Otherwise, false.spring-doc.cn
modelspring-doc.cn
The parent context variables (see TextComponentContext Template Variables).spring-doc.cn
