验证
Spring Shell 与 Bean 验证 API 集成以支持 命令参数的自动和自记录约束。spring-doc.cadn.net.cn
在命令参数上找到的注释和方法级别的注释是 honoured 并在命令执行之前触发验证。请考虑以下命令:spring-doc.cadn.net.cn
	@ShellMethod("Change password.")
	public String changePassword(@Size(min = 8, max = 40) String password) {
		return "Password successfully set to " + password;
从前面的示例中,您可以免费获得以下行为:spring-doc.cadn.net.cn
shell:>change-password hello
The following constraints were not met:
	--password string : size must be between 8 and 40 (You passed 'hello')
