此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Security 6.4.3! |
Java 配置
在 Spring 3.1 中,Spring Framework 中添加了对 Java 配置的一般支持。 Spring Security 3.2 引入了 Java 配置,允许用户在不使用任何 XML 的情况下配置 Spring Security。
如果您熟悉 Security Namespace Configuration,您应该会发现它与 Spring Security Java 配置之间有很多相似之处。
Spring Security 提供了许多示例应用程序来演示 Spring Security Java Configuration 的使用。 |
Hello Web Security Java 配置
第一步是创建我们的 Spring Security Java 配置。
该配置将创建一个称为springSecurityFilterChain
,它负责应用程序中的所有安全性(保护应用程序 URL、验证提交的用户名和密码、重定向到登录表单等)。
以下示例显示了 Spring Security Java 配置的最基本示例:
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.context.annotation.*;
import org.springframework.security.config.annotation.authentication.builders.*;
import org.springframework.security.config.annotation.web.configuration.*;
@EnableWebSecurity
public class WebSecurityConfig {
public UserDetailsService userDetailsService() {
InMemoryUserDetailsManager manager = new InMemoryUserDetailsManager();
manager.createUser(User.withDefaultPasswordEncoder().username("user").password("password").roles("USER").build());
return manager;
This configuration is not complex or extensive, but it does a lot:
Require authentication to every URL in your application
Generate a login form for you
Let the user with a Username of user
and a Password of password
authenticate with form based authentication
Let the user logout
CSRF attack prevention
Session Fixation protection
Security Header integration:
HTTP Strict Transport Security for secure requests
X-Content-Type-Options integration
Cache Control (which you can override later in your application to allow caching of your static resources)
X-XSS-Protection integration
X-Frame-Options integration to help prevent Clickjacking
Integration with the following Servlet API methods:
AbstractSecurityWebApplicationInitializer
The next step is to register the springSecurityFilterChain
with the WAR file.
You can do so in Java configuration with Spring’s WebApplicationInitializer
support in a Servlet 3.0+ environment.
Not surprisingly, Spring Security provides a base class (AbstractSecurityWebApplicationInitializer
) to ensure that the springSecurityFilterChain
gets registered for you.
The way in which we use AbstractSecurityWebApplicationInitializer
differs depending on if we are already using Spring or if Spring Security is the only Spring component in our application.
AbstractSecurityWebApplicationInitializer without Existing Spring - Use these instructions if you are not already using Spring
AbstractSecurityWebApplicationInitializer with Spring MVC - Use these instructions if you are already using Spring
If you are not using Spring or Spring MVC, you need to pass the WebSecurityConfig
to the superclass to ensure the configuration is picked up:
import org.springframework.security.web.context.*;
public class SecurityWebApplicationInitializer
extends AbstractSecurityWebApplicationInitializer {
public SecurityWebApplicationInitializer() {
super(WebSecurityConfig.class);
The SecurityWebApplicationInitializer
Automatically registers the springSecurityFilterChain
Filter for every URL in your application.
Add a ContextLoaderListener
that loads the WebSecurityConfig.
If we use Spring elsewhere in our application, we probably already have a WebApplicationInitializer
that is loading our Spring Configuration.
If we use the previous configuration, we would get an error.
Instead, we should register Spring Security with the existing ApplicationContext
For example, if we use Spring MVC, our SecurityWebApplicationInitializer
could look something like the following:
This onlys register the springSecurityFilterChain
After that, we need to ensure that WebSecurityConfig
was loaded in our existing ApplicationInitializer
For example, if we use Spring MVC it is added in the getServletConfigClasses()
public class MvcWebApplicationInitializer extends
AbstractAnnotationConfigDispatcherServletInitializer {
protected Class<?>[] getServletConfigClasses() {
return new Class[] { WebSecurityConfig.class, WebMvcConfig.class };
// ... other overrides ...
The reason for this is that Spring Security needs to be able to inspect some Spring MVC configuration in order to appropriately configure underlying request matchers, so they need to be in the same application context.
Placing Spring Security in getRootConfigClasses
places it into a parent application context that may not be able to find Spring MVC’s HandlerMappingIntrospector
Configuring for Multiple Spring MVC Dispatchers
If desired, any Spring Security configuration that is unrelated to Spring MVC may be placed in a different configuration class like so:
protected Class<?>[] getRootConfigClasses() {
return new Class[] { NonWebSecurityConfig.class };
This can be helpful if you have multiple instances of AbstractAnnotationConfigDispatcherServletInitializer
and don’t want to duplicate the general security configuration across both of them.
HttpSecurity
Thus far, our WebSecurityConfig
contains only information about how to authenticate our users.
How does Spring Security know that we want to require all users to be authenticated?
How does Spring Security know we want to support form-based authentication?
Actually, there is a configuration class (called SecurityFilterChain
) that is being invoked behind the scenes.
It is configured with the following default implementation:
http
.authorizeRequests(authorize -> authorize
.anyRequest().authenticated()
.formLogin(withDefaults())
.httpBasic(withDefaults());
return http.build();
The default configuration (shown in the preceding example):
Ensures that any request to our application requires the user to be authenticated
Lets users authenticate with form based login
Lets users authenticate with HTTP Basic authentication
Note that this configuration is parallels the XML Namespace configuration:
<http>
<intercept-url pattern="/**" access="authenticated"/>
<form-login />
<http-basic />
</http>
Multiple HttpSecurity Instances
We can configure multiple HttpSecurity
instances just as we can have multiple <http>
blocks in XML.
The key is to register multiple SecurityFilterChain
s.
The following example has a different configuration for URL’s that start with /api/
@EnableWebSecurity
public class MultiHttpSecurityConfig {
@Bean (1)
public UserDetailsService userDetailsService() throws Exception {
// ensure the passwords are encoded properly
UserBuilder users = User.withDefaultPasswordEncoder();
manager.createUser(users.username("user").password("password").roles("USER").build());
manager.createUser(users.username("admin").password("password").roles("USER","ADMIN").build());
return manager;
@Order(1) (2)
public SecurityFilterChain apiFilterChain(HttpSecurity http) throws Exception {
http
.securityMatcher("/api/**") (3)
.anyRequest().hasRole("ADMIN")
@Bean (4)
public SecurityFilterChain formLoginFilterChain(HttpSecurity http) throws Exception {
http
.formLogin(withDefaults());
1
Configure Authentication as usual.
2
Create an instance of SecurityFilterChain
that contains @Order
to specify which SecurityFilterChain
should be considered first.
3
The http.securityMatcher
states that this HttpSecurity
is applicable only to URLs that start with /api/
4
Create another instance of SecurityFilterChain
If the URL does not start with /api/
, this configuration is used.
This configuration is considered after apiFilterChain
, since it has an @Order
value after 1
(no @Order
defaults to last).
Custom DSLs
You can provide your own custom DSLs in Spring Security:
public class MyCustomDsl extends AbstractHttpConfigurer<MyCustomDsl, HttpSecurity> {
private boolean flag;
public void init(HttpSecurity http) throws Exception {
// any method that adds another configurer
// must be done in the init method
http.csrf().disable();
public void configure(HttpSecurity http) throws Exception {
ApplicationContext context = http.getSharedObject(ApplicationContext.class);
// here we lookup from the ApplicationContext. You can also just create a new instance.
MyFilter myFilter = context.getBean(MyFilter.class);
myFilter.setFlag(flag);
http.addFilterBefore(myFilter, UsernamePasswordAuthenticationFilter.class);
public MyCustomDsl flag(boolean value) {
this.flag = value;
return this;
public static MyCustomDsl customDsl() {
return new MyCustomDsl();
This is actually how methods like HttpSecurity.authorizeRequests()
are implemented.
You can then use the custom DSL:
@EnableWebSecurity
public class Config {
http
.apply(customDsl())
.flag(true)
.and()
The code is invoked in the following order:
Code in the Config.filterChain
method is invoked
Code in the MyCustomDsl.init
method is invoked
Code in the MyCustomDsl.configure
method is invoked
If you want, you can have HttpSecurity
add MyCustomDsl
by default by using SpringFactories
For example, you can create a resource on the classpath named META-INF/spring.factories
with the following contents:
org.springframework.security.config.annotation.web.configurers.AbstractHttpConfigurer = sample.MyCustomDsl
You can also explicit disable the default:
@EnableWebSecurity
http
.apply(customDsl()).disable()
Post Processing Configured Objects
Spring Security’s Java configuration does not expose every property of every object that it configures.
This simplifies the configuration for a majority of users.
After all, if every property were exposed, users could use standard bean configuration.
While there are good reasons to not directly expose every property, users may still need more advanced configuration options.
To address this issue, Spring Security introduces the concept of an ObjectPostProcessor
, which can be used to modify or replace many of the Object
instances created by the Java Configuration.
For example, to configure the filterSecurityPublishAuthorizationSuccess
property on FilterSecurityInterceptor
, you can use the following:
http
.withObjectPostProcessor(new ObjectPostProcessor<FilterSecurityInterceptor>() {
public <O extends FilterSecurityInterceptor> O postProcess(
O fsi) {
fsi.setPublishAuthorizationSuccess(true);
return fsi;
