Pulsar Client
When you use the Pulsar Spring Boot Starter, you get the PulsarClient
auto-configured.
By default, the application tries to connect to a local Pulsar instance at pulsar://localhost:6650
This can be adjusted by setting the spring.pulsar.client.service-url
property to a different value.
The value must be a valid Pulsar Protocol URL |
You can further configure the client by specifying any of the spring.pulsar.client.*
application properties.
If you are not using the starter, you will need to configure and register the PulsarClient yourself.
There is a DefaultPulsarClientFactory that accepts a builder customizer that can be used to help with this.
1. TLS Encryption (SSL)
By default, Pulsar clients communicate with Pulsar services in plain text. The following section describes how to configure Pulsar clients to use TLS encryption (SSL). A pre-requisite is that the Broker has also been configured to use TLS encryption.
The Spring Boot auto-configuration does not currently support any TLS/SSL configuration properties.
You can instead provide a PulsarClientBuilderCustomizer
that sets the necessary properties on the Pulsar client builder.
Pulsar supports both Privacy Enhanced Mail (PEM) and Java KeyStore (JKS) certificate formats.
Follow these steps to configure TLS:
Adjust the Pulsar client service url to use the
pulsar+ssl://
scheme and TLS port (typically6651
Adjust the admin client service url to use the
https://
scheme and TLS web port (typically8443
Provide client builder customizer(s) that sets the relevant properties on the builder.
You can find more information on the above in the official Pulsar TLS Encryption documentation.
2. Authentication
To connect to a Pulsar cluster that requires authentication, you need to specify which authentication plugin to use and any parameters required by the specified plugin. When using Spring Boot auto-configuration, you can set the plugin and the plugin parameters via configuration properties (in most cases).
You need to ensure that names defined under For example, if you want to configure the issuer url for the |
Using environment variables for auth parameters is typically problematic because the case sensitivity is lost during translation.
For example, consider the following
When Spring Boot loads this property it will use
When not using Spring Boot auto-configuration, you can use the org.apache.pulsar.client.api.AuthenticationFactory
to create the authentication and then set it directly on the Pulsar client builder in a client customizer that you provide to the client factory.
The following listings show how to configure each of the supported authentication mechanisms.
Click here for Athenz
spring: pulsar: client: authentication: plugin-class-name: org.apache.pulsar.client.impl.auth.AuthenticationAthenz param: tenantDomain: ... tenantService: ... providerDomain: ... privateKey: ... keyId: ...
This also requires TLS encryption. |
Click here for Token
spring: pulsar: client: authentication: plugin-class-name: org.apache.pulsar.client.impl.auth.AuthenticationToken param: token: some-token-goes-here
Click here for Basic
spring: pulsar: client: authentication: plugin-class-name: org.apache.pulsar.client.impl.auth.AuthenticationBasic param: userId: ... password: ...
Click here for OAuth2
spring: pulsar: client: authentication: plugin-class-name: org.apache.pulsar.client.impl.auth.oauth2.AuthenticationOAuth2 param: issuerUrl: ... privateKey: ... audience: ... scope: ...
Click here for Sasl
spring: pulsar: client: authentication: plugin-class-name: org.apache.pulsar.client.impl.auth.AuthenticationSasl param: saslJaasClientSectionName: ... serverType: ...
Click here for mTLS (PEM)
Because this option requires TLS encryption, which already requires you to provide a client builder customizer, it is recommended to simply add the authentication directly on the client builder in your provided TLS customizer.
You can use the org.apache.pulsar.client.api.AuthenticationFactory to help create the authentication object as follows:
Authentication auth = AuthenticationFactory.TLS("/path/to/my-role.cert.pem", "/path/to/my-role.key-pk8.pem");
See the official Pulsar documentation on mTLS (PEM).
Click here for mTLS (JKS)
Authentication auth = AuthenticationFactory.create(
"org.apache.pulsar.client.impl.auth.AuthenticationKeyStoreTls",
Map.of("keyStoreType", "JKS", "keyStorePath", "/path/to/my/keystore.jks", "keyStorePassword", "clientpw"));
See the official Pulsar documentation on mTLS (JKS).
You can find more information on each of the support plugins and their required properties in the official Pulsar security documentation.
3. Automatic Cluster-Level Failover
The Pulsar Spring Boot Starter also auto-configures the PulsarClient
for automatic cluster-level failover.
You can use the spring.pulsar.client.failover.*
application properties to configure cluster-level failover.
The following example configures the client with a primary and two backup clusters.
spring:
pulsar:
client:
service-url: "pulsar://my.primary.server:6650"
failover:
delay: 30s
switch-back-delay: 15s
check-interval: 1s
backup-clusters:
- service-url: "pulsar://my.second.server:6650"
authentication:
param:
token: "my-token"
- service-url: "pulsar://my.third.server:6650"
In addition to the client configuration, there a few prerequisites on the broker that must be satisfied in order to use this feature. |
When not using Spring Boot auto-configuration, you can provide a client customizer that configures the client for cluster-level failover.
