Custom Object Mapper
Pulsar uses an internal Jackson ObjectMapper when de/serializing JSON messages. If you instead want to provide your own object mapper instance, you can register a SchemaResolverCustomizer and set your mapper on the DefaultSchemaResolver as follows:spring-doc.cn
SchemaResolverCustomizer<DefaultSchemaResolver> schemaResolverCustomizer() {
    return (DefaultSchemaResolver schemaResolver) -> {
        var myObjectMapper = obtainMyObjectMapper();
        schemaResolver.setObjectMapper(myObjectMapper);
This results in your object mapper being used to de/serialize all JSON messages that go through the schema resolution process (i.e. in cases where you do not pass a schema in directly when producing/consuming messages).spring-doc.cn
Under the hood, the resolver creates a special JSON schema which leverages the custom mapper and is used as the schema for all resolved JSON messages.spring-doc.cn
If you need to pass schema instances directly you can use the JSONSchemaUtil to create schemas that respect the custom mapper. The following example shows how to do this when sending a message with the PulsarTemplate variant that takes a schema parameter:spring-doc.cn
void sendMessage(PulsarTemplate<MyPojo> template, MyPojo toSend) {
    var schema = JSONSchemaUtil.schemaForTypeWithObjectMapper(MyPojo.class, myObjectMapper);
    template.send(toSend, schema);
Pulsar configures its default object mapper in a particular way. Unless you have a specific reason to not do so, it is highly recommended that you configure your mapper with these same options as follows:spring-doc.cn
myObjectMapper.configure(DeserializationFeature.FAIL_ON_UNKNOWN_PROPERTIES, false);
myObjectMapper.configure(DeserializationFeature.READ_UNKNOWN_ENUM_VALUES_AS_NULL, false);
myObjectMapper.setSerializationInclusion(JsonInclude.Include.NON_NULL);
A later version of the framework may instead provide a customizer that operates on the default mapper rather than requiring a separate instance.
