This version is still in development and is not considered stable yet. For the latest stable version, please use Spring for Apache Kafka 3.3.6! |
DLT Strategies
The framework provides a few strategies for working with DLTs. You can provide a method for DLT processing, use the default logging method, or have no DLT at all. Also you can choose what happens if DLT processing fails.
DLT Processing Method
You can specify the method used to process the DLT for the topic, as well as the behavior if that processing fails.
To do that you can use the @DltHandler
annotation in a method of the class with the @RetryableTopic
annotation(s).
Note that the same method will be used for all the @RetryableTopic
annotated methods within that class.
@RetryableTopic
@KafkaListener(topics = "my-annotated-topic")
public void processMessage(MyPojo message) {
// ... message processing
@DltHandler
// ... message processing, persistence, etc
The DLT handler method can also be provided through the RetryTopicConfigurationBuilder.dltHandlerMethod(String, String)
method, passing as arguments the bean name and method name that should process the DLT’s messages.
public RetryTopicConfiguration myRetryTopic(KafkaTemplate<Integer, MyPojo> template) {
return RetryTopicConfigurationBuilder
.newInstance()
.dltHandlerMethod("myCustomDltProcessor", "processDltMessage")
.create(template);
@Component
public class MyCustomDltProcessor {
private final MyDependency myDependency;
public MyCustomDltProcessor(MyDependency myDependency) {
this.myDependency = myDependency;
public void processDltMessage(MyPojo message) {
If no DLT handler is provided, the default RetryTopicConfigurer.LoggingDltListenerHandlerMethod is used.
Starting with version 2.8, if you don’t want to consume from the DLT in this application at all, including by the default handler (or you wish to defer consumption), you can control whether or not the DLT container starts, independent of the container factory’s autoStartup
property.
When using the @RetryableTopic
annotation, set the autoStartDltHandler
property to false
; when using the configuration builder, use autoStartDltHandler(false)
You can later start the DLT handler via the KafkaListenerEndpointRegistry
DLT Failure Behavior
Should the DLT processing fail, there are two possible behaviors available: ALWAYS_RETRY_ON_ERROR
and FAIL_ON_ERROR
In the former the record is forwarded back to the DLT topic so it doesn’t block other DLT records' processing. In the latter the consumer ends the execution without forwarding the message.
@RetryableTopic(dltProcessingFailureStrategy =
DltStrategy.FAIL_ON_ERROR)
.newInstance()
.doNotRetryOnDltFailure()
.create(template);
The default behavior is to ALWAYS_RETRY_ON_ERROR .
Starting with version 2.8.3, ALWAYS_RETRY_ON_ERROR will NOT route a record back to the DLT if the record causes a fatal exception to be thrown,
such as a DeserializationException , because, generally, such exceptions will always be thrown.
Exceptions that are considered fatal are:
MessageConversionException
ConversionException
MethodArgumentResolutionException
NoSuchMethodException
ClassCastException
You can add exceptions to and remove exceptions from this list using methods on the DestinationTopicResolver
bean.
See Exception Classifier for more information.
Configuring No DLT
The framework also provides the possibility of not configuring a DLT for the topic. In this case after retrials are exhausted the processing simply ends.
DltStrategy.NO_DLT)
.newInstance()
.doNotConfigureDlt()
.create(template);
