This version is still in development and is not considered stable yet. For the latest stable version, please use Spring for Apache Kafka 3.3.6! |
Exactly Once Semantics
You can provide a listener container with a KafkaAwareTransactionManager
instance.
When so configured, the container starts a transaction before invoking the listener.
Any KafkaTemplate
operations performed by the listener participate in the transaction.
If the listener successfully processes the record (or multiple records, when using a BatchMessageListener
), the container sends the offset(s) to the transaction by using producer.sendOffsetsToTransaction()
), before the transaction manager commits the transaction.
If the listener throws an exception, the transaction is rolled back and the consumer is repositioned so that the rolled-back record(s) can be retrieved on the next poll.
See After-rollback Processor for more information and for handling records that repeatedly fail.
Using transactions enables Exactly Once Semantics (EOS).
This means that, for a read → process → write
sequence, it is guaranteed that the sequence is completed exactly once.
(The read and process have at least once semantics).
Spring for Apache Kafka version 3.0 and later only supports EOSMode.V2
V2
- aka fetch-offset-request fencing (since version 2.5)
This requires the brokers to be version 2.5 or later. |
With mode V2
, it is not necessary to have a producer for each group.id/topic/partition
because consumer metadata is sent along with the offsets to the transaction and the broker can determine if the producer is fenced using that information instead.
Refer to KIP-447 for more information.
V2
was previously BETA
; the EOSMode
has been changed to align the framework with KIP-732.
