This version is still in development and is not considered stable yet. For the latest stable version, please use Spring for Apache Kafka 3.3.6! |
@KafkaListener
on a Class
When you use @KafkaListener
at the class-level, you must specify @KafkaHandler
at the method level.
When messages are delivered, the converted message payload type is used to determine which method to call.
The following example shows how to do so:
@KafkaListener(id = "multi", topics = "myTopic")
static class MultiListenerBean {
@KafkaHandler
public void listen(String foo) {
@KafkaHandler
public void listen(Integer bar) {
@KafkaHandler(isDefault = true)
public void listenDefault(Object object) {
Starting with version 2.1.3, you can designate a @KafkaHandler
method as the default method that is invoked if there is no match on other methods.
At most, one method can be so designated.
When using @KafkaHandler
methods, the payload must have already been converted to the domain object (so the match can be performed).
Use a custom deserializer, the JsonDeserializer
, or the JsonMessageConverter
with its TypePrecedence
set to TYPE_ID
See Serialization, Deserialization, and Message Conversion for more information.
Due to some limitations in the way Spring resolves method arguments, a default @KafkaHandler cannot receive discrete headers; it must use the ConsumerRecordMetadata as discussed in Consumer Record Metadata.
For example:
public void listenDefault(Object object, @Header(KafkaHeaders.RECEIVED_TOPIC) String topic) {
This won’t work if the object is a String
; the topic
parameter will also get a reference to object
If you need metadata about the record in a default method, use this:
void listen(Object in, @Header(KafkaHeaders.RECORD_METADATA) ConsumerRecordMetadata meta) {
String topic = meta.topic();
