This version is still in development and is not considered stable yet. For the latest stable version, please use Spring for Apache Kafka 3.3.6! |
@KafkaListener
Attribute Modification
Starting with version 2.7.2, you can now programmatically modify annotation attributes before the container is created.
To do so, add one or more KafkaListenerAnnotationBeanPostProcessor.AnnotationEnhancer
to the application context.
AnnotationEnhancer
is a BiFunction<Map<String, Object>, AnnotatedElement, Map<String, Object>
and must return a map of attributes.
The attribute values can contain SpEL and/or property placeholders; the enhancer is called before any resolution is performed.
If more than one enhancer is present, and they implement Ordered
, they will be invoked in order.
AnnotationEnhancer bean definitions must be declared static because they are required very early in the application context’s lifecycle.
An example follows:
public static AnnotationEnhancer groupIdEnhancer() {
return (attrs, element) -> {
attrs.put("groupId", attrs.get("id") + "." + (element instanceof Class
? ((Class<?>) element).getSimpleName()
: ((Method) element).getDeclaringClass().getSimpleName()
+ "." + ((Method) element).getName()));
return attrs;
