For the latest stable version, please use Spring Data JPA 3.4.5! |
Configuration
This section describes configuring Spring Data JPA through either:
“Annotation-based Configuration” (Java configuration)
“Spring Namespace” (XML configuration)
The Spring Data JPA repositories support can be activated through both JavaConfig as well as a custom XML namespace, as shown in the following example:
@EnableJpaRepositories
@EnableTransactionManagement
class ApplicationConfig {
public DataSource dataSource() {
EmbeddedDatabaseBuilder builder = new EmbeddedDatabaseBuilder();
return builder.setType(EmbeddedDatabaseType.HSQL).build();
public LocalContainerEntityManagerFactoryBean entityManagerFactory() {
HibernateJpaVendorAdapter vendorAdapter = new HibernateJpaVendorAdapter();
vendorAdapter.setGenerateDdl(true);
LocalContainerEntityManagerFactoryBean factory = new LocalContainerEntityManagerFactoryBean();
factory.setJpaVendorAdapter(vendorAdapter);
factory.setPackagesToScan("com.acme.domain");
factory.setDataSource(dataSource());
return factory;
public PlatformTransactionManager transactionManager(EntityManagerFactory entityManagerFactory) {
JpaTransactionManager txManager = new JpaTransactionManager();
txManager.setEntityManagerFactory(entityManagerFactory);
return txManager;
You must create LocalContainerEntityManagerFactoryBean and not EntityManagerFactory directly, since the former also participates in exception translation mechanisms in addition to creating EntityManagerFactory .
The preceding configuration class sets up an embedded HSQL database by using the EmbeddedDatabaseBuilder
API of spring-jdbc
. Spring Data then sets up an EntityManagerFactory
and uses Hibernate as the sample persistence provider. The last infrastructure component declared here is the JpaTransactionManager
. Finally, the example activates Spring Data JPA repositories by using the @EnableJpaRepositories
annotation, which essentially carries the same attributes as the XML namespace. If no base package is configured, it uses the one in which the configuration class resides.
Spring Namespace
The JPA module of Spring Data contains a custom namespace that allows defining repository beans. It also contains certain features and element attributes that are special to JPA. Generally, the JPA repositories can be set up by using the repositories
element, as shown in the following example:
xmlns:jpa="http://www.springframework.org/schema/data/jpa"
https://www.springframework.org/schema/data/jpa/spring-jpa.xsd">
<jpa:repositories base-package="com.acme.repositories" />
</beans>
Which is better, JavaConfig or XML? XML is how Spring was configured long ago. In today’s era of fast-growing Java, record types, annotations, and more, new projects typically use as much pure Java as possible. While there is no immediate plan to remove XML support, some of the newest features MAY not be available through XML. |
Using the repositories
element it activates persistence exception translation for all beans annotated with @Repository
, to let exceptions being thrown by the JPA persistence providers be converted into Spring’s DataAccessException
hierarchy.
Custom Namespace Attributes
Beyond the default attributes of the repositories
element, the JPA namespace offers additional attributes to let you gain more detailed control over the setup of the repositories:
Explicitly wire the |
Spring Data JPA requires a PlatformTransactionManager bean named transactionManager to be present if no explicit transaction-manager-ref is defined.
Bootstrap Mode
By default, Spring Data JPA repositories are default Spring beans.
They are singleton scoped and eagerly initialized.
During startup, they already interact with the JPA EntityManager
for verification and metadata analysis purposes.
Spring Framework supports the initialization of the JPA EntityManagerFactory
in a background thread because that process usually takes up a significant amount of startup time in a Spring application.
To make use of that background initialization effectively, we need to make sure that JPA repositories are initialized as late as possible.
As of Spring Data JPA 2.1 you can now configure a BootstrapMode
(either via the @EnableJpaRepositories
annotation or the XML namespace) that takes the following values:
DEFAULT
(default) — Repositories are instantiated eagerly unless explicitly annotated with@Lazy
. The lazification only has effect if no client bean needs an instance of the repository as that will require the initialization of the repository bean. -
LAZY
— Implicitly declares all repository beans lazy and also causes lazy initialization proxies to be created to be injected into client beans. That means, that repositories will not get instantiated if the client bean is simply storing the instance in a field and not making use of the repository during initialization. Repository instances will be initialized and verified upon first interaction with the repository. -
DEFERRED
— Fundamentally the same mode of operation asLAZY
, but triggering repository initialization in response to anContextRefreshedEvent
so that repositories are verified before the application has completely started.
Recommendations
If you’re not using asynchronous JPA bootstrap stick with the default bootstrap mode.
In case you bootstrap JPA asynchronously, DEFERRED
is a reasonable default as it will make sure the Spring Data JPA bootstrap only waits for the EntityManagerFactory
setup if that itself takes longer than initializing all other application components.
Still, it makes sure that repositories are properly initialized and validated before the application signals it’s up.
LAZY
is a decent choice for testing scenarios and local development.
Once you are pretty sure that repositories can properly bootstrap, or in cases where you are testing other parts of the application, running verification for all repositories might unnecessarily increase the startup time.
The same applies to local development in which you only access parts of the application that might need to have a single repository initialized.
