For the latest stable version, please use Spring Data JPA 3.4.5!spring-doc.cn
Getting Started
An easy way to bootstrap setting up a working environment is to create a Spring-based project via start.spring.io or create a Spring project in Spring Tools.spring-doc.cn
Examples Repository
The GitHub spring-data-examples repository hosts several examples that you can download and play around with to get a feel for how the library works.spring-doc.cn
Hello World
Let’s start with a simple entity and its corresponding repository:spring-doc.cn
@Entity
class Person {
  @Id @GeneratedValue(strategy = GenerationType.AUTO)
  private Long id;
  private String name;
  // getters and setters omitted for brevity
interface PersonRepository extends Repository<Person, Long> {
  Person save(Person person);
  Optional<Person> findById(long id);
Create the main application to run, as the following example shows:spring-doc.cn
@SpringBootApplication
public class DemoApplication {
    SpringApplication.run(DemoApplication.class, args);
  CommandLineRunner runner(PersonRepository repository) {
    return args -> {
      Person person = new Person();
      person.setName("John");
      repository.save(person);
      Person saved = repository.findById(person.getId()).orElseThrow(NoSuchElementException::new);
Even in this simple example, there are a few notable things to point out:spring-doc.cn
  • Repository instances are automatically implemented. When used as parameters of @Bean methods, these will be autowired without further need for annotations.spring-doc.cn
  • The basic repository extends Repository. We suggest to consider how much API surface you want to expose towards your application. More complex repository interfaces are ListCrudRepository or JpaRepository.spring-doc.cn
