For the latest stable version, please use Spring Data JPA 3.4.5! |
Stored Procedures
The JPA 2.1 specification introduced support for calling stored procedures by using the JPA criteria query API.
We Introduced the @Procedure
annotation for declaring stored procedure metadata on a repository method.
The examples to follow use the following stored procedure:
plus1inout
procedure in HSQL DB./;
DROP procedure IF EXISTS plus1inout
CREATE procedure plus1inout (IN arg int, OUT res int)
BEGIN ATOMIC
set res = arg + 1;
END
Metadata for stored procedures can be configured by using the NamedStoredProcedureQuery
annotation on an entity type.
@Entity
@NamedStoredProcedureQuery(name = "User.plus1", procedureName = "plus1inout", parameters = {
@StoredProcedureParameter(mode = ParameterMode.IN, name = "arg", type = Integer.class),
@StoredProcedureParameter(mode = ParameterMode.OUT, name = "res", type = Integer.class) })
public class User {}
Note that @NamedStoredProcedureQuery
has two different names for the stored procedure.
name
is the name JPA uses. procedureName
is the name the stored procedure has in the database.
You can reference stored procedures from a repository method in multiple ways.
The stored procedure to be called can either be defined directly by using the value
or procedureName
attribute of the @Procedure
annotation.
This refers directly to the stored procedure in the database and ignores any configuration via @NamedStoredProcedureQuery
Alternatively you may specify the @NamedStoredProcedureQuery.name
attribute as the @Procedure.name
attribute.
If neither value
, procedureName
nor name
is configured, the name of the repository method is used as the name
attribute.
The following example shows how to reference an explicitly mapped procedure:
@Procedure("plus1inout")
Integer explicitlyNamedPlus1inout(Integer arg);
The following example is equivalent to the previous one but uses the procedureName
alias:
procedureName
alias.@Procedure(procedureName = "plus1inout")
Integer callPlus1InOut(Integer arg);
The following is again equivalent to the previous two but using the method name instead of an explicit annotation attribute.
EntityManager
by using the method name.@Procedure
Integer plus1inout(@Param("arg") Integer arg);
The following example shows how to reference a stored procedure by referencing the @NamedStoredProcedureQuery.name
attribute.
EntityManager
.@Procedure(name = "User.plus1IO")
Integer entityAnnotatedCustomNamedProcedurePlus1IO(@Param("arg") Integer arg);
If the stored procedure getting called has a single out parameter that parameter may be returned as the return value of the method.
If there are multiple out parameters specified in a @NamedStoredProcedureQuery
annotation those can be returned as a Map
with the key being the parameter name given in the @NamedStoredProcedureQuery
annotation.
Note that if the stored procedure returns a ResultSet then any OUT parameters are omitted as Java can only return a single method return value unless the method declares a Map return type.
The following example shows how to obtain multiple OUT
parameters if the stored procedure has multiple OUT
parameters and is registered as @NamedStoredProcedureQuery
. @NamedStoredProcedureQuery
registration is required to provide parameter metadata.
@Entity
@NamedStoredProcedureQuery(name = "User.multiple_out_parameters", procedureName = "multiple_out_parameters", parameters = {
@StoredProcedureParameter(mode = ParameterMode.REF_CURSOR, name = "some_cursor", type = void.class),
@Procedure(name = "User.multiple_out_parameters")
Map<String, Object> returnsMultipleOutParameters(@Param("arg") Integer arg);
