For the latest stable version, please use Spring Data JPA 3.4.5! |
Glossary
- AOP
Aspect oriented programming
- Commons DBCP
Commons DataBase Connection Pools - a library from the Apache foundation that offers pooling implementations of the DataSource interface.
- CRUD
Create, Read, Update, Delete - Basic persistence operations.
- DAO
Data Access Object - Pattern to separate persisting logic from the object to be persisted
- Dependency Injection
Pattern to hand a component’s dependency to the component from outside, freeing the component to lookup the dependent itself. For more information, see en.wikipedia.org/wiki/Dependency_Injection.
- EclipseLink
Object relational mapper implementing JPA - www.eclipse.org/eclipselink/
- Hibernate
Object relational mapper implementing JPA - hibernate.org/
- JPA
Jakarta Persistence API
- Spring
Java application framework - spring.io/projects/spring-framework
