此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 spring-cloud-stream 4.2.0! |
KafkaBindingRebalanceListener 函数
应用程序可能希望在最初分配分区时将主题/分区查找到任意偏移量,或对使用者执行其他作。
从版本 2.1 开始,如果您提供单个KafkaBindingRebalanceListener
bean 时,它将被连接到所有 Kafka 消费者绑定中。
public interface KafkaBindingRebalanceListener {
* Invoked by the container before any pending offsets are committed.
* @param bindingName the name of the binding.
* @param consumer the consumer.
* @param partitions the partitions.
default void onPartitionsRevokedBeforeCommit(String bindingName, Consumer<?, ?> consumer,
Collection<TopicPartition> partitions) {
* Invoked by the container after any pending offsets are committed.
default void onPartitionsRevokedAfterCommit(String bindingName, Consumer<?, ?> consumer, Collection<TopicPartition> partitions) {
* Invoked when partitions are initially assigned or after a rebalance.
* Applications might only want to perform seek operations on an initial assignment.
* @param initial true if this is the initial assignment.
default void onPartitionsAssigned(String bindingName, Consumer<?, ?> consumer, Collection<TopicPartition> partitions,
boolean initial) {
您无法设置resetOffsets
consumer 属性设置为true
当您提供 Rebalance 侦听器时。
