This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Cloud Kubernetes 3.2.0!spring-doc.cn
Reload namespace and label filtering
By default, a namespace chosen using the steps outlined in Namespace resolution will be used to listen to changes in configmaps and secrets. i.e.: if you do not tell reload what namespaces and configmaps/secrets to watch for, it will watch all configmaps/secrets from the namespace that will be computed using the above algorithm.spring-doc.cn
On the other hand, you can define a more fine-grained approach. For example, you can specify the namespaces where changes will be monitored:spring-doc.cn
spring:
  application:
  cloud:
    kubernetes:
      reload:
        enabled: true
        strategy: shutdown
        mode: event
        namespaces:
          - my-namespace
Such a configuration will make the app watch changes only in the my-namespace namespace. Mind that this will watch all configmaps/secrets (depending on which one you enable). If you want an even more fine-grained approach, you can enable "label-filtering". First we need to enable such support via : enable-reload-filtering: truespring-doc.cn
spring:
  application:
  cloud:
    kubernetes:
      reload:
        enabled: true
        strategy: shutdown
        mode: event
        namespaces:
          - my-namespaces
        monitoring-config-maps: true
What this will do, is watch configmaps/secrets that only have the spring.cloud.kubernetes.config.informer.enabled: true label.spring-doc.cn
Table 1. Properties:
Name Type Default Description
spring.cloud.kubernetes.reload.enabledspring-doc.cn
Booleanspring-doc.cn
falsespring-doc.cn
Enables monitoring of property sources and configuration reloadspring-doc.cn
spring.cloud.kubernetes.reload.monitoring-config-mapsspring-doc.cn
truespring-doc.cn
Allow monitoring changes in config mapsspring-doc.cn
spring.cloud.kubernetes.reload.monitoring-secretsspring-doc.cn
falsespring-doc.cn
Allow monitoring changes in secretsspring-doc.cn
spring.cloud.kubernetes.reload.strategyspring-doc.cn
Enumspring-doc.cn
refreshspring-doc.cn
The strategy to use when firing a reload (refresh, restart_context, or shutdown)spring-doc.cn
spring.cloud.kubernetes.reload.modespring-doc.cn
Enumspring-doc.cn
eventspring-doc.cn
Specifies how to listen for changes in property sources (event or polling)spring-doc.cn
spring.cloud.kubernetes.reload.periodspring-doc.cn
Durationspring-doc.cn
15sspring-doc.cn
The period for verifying changes when using the polling strategyspring-doc.cn
spring.cloud.kubernetes.reload.namespacesspring-doc.cn
String[]spring-doc.cn
namespaces where we should watch for changesspring-doc.cn
spring.cloud.kubernetes.reload.enable-reload-filteringspring-doc.cn
Stringspring-doc.cn
enabled labeled filtering for reload functionalityspring-doc.cn
  • You should not use properties under spring.cloud.kubernetes.reload in config maps or secrets. Changing such properties at runtime may lead to unexpected results.spring-doc.cn
  • Deleting a property or the whole config map does not restore the original state of the beans when you use the refresh level.spring-doc.cn
