This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Cloud Kubernetes 3.2.0!spring-doc.cn
Security Configurations Inside Kubernetes
Namespace
Most of the components provided in this project need to know the namespace. For Kubernetes (1.3+), the namespace is made available to the pod as part of the service account secret and is automatically detected by the client. For earlier versions, it needs to be specified as an environment variable to the pod. A quick way to do this is as follows:spring-doc.cn
      env:
      - name: "KUBERNETES_NAMESPACE"
        valueFrom:
          fieldRef:
            fieldPath: "metadata.namespace"
Service Account
For distributions of Kubernetes that support more fine-grained role-based access within the cluster, you need to make sure a pod that runs with spring-cloud-kubernetes has access to the Kubernetes API. For any service accounts you assign to a deployment or pod, you need to make sure they have the correct roles.spring-doc.cn
Depending on the requirements, you’ll need get, list and watch permission on the following resources:spring-doc.cn
Table 1. Kubernetes Resource Permissions
Dependency Resources
spring-cloud-starter-kubernetes-fabric8spring-doc.cn
pods, services, endpointsspring-doc.cn
spring-cloud-starter-kubernetes-fabric8-configspring-doc.cn
configmaps, secretsspring-doc.cn
spring-cloud-starter-kubernetes-clientspring-doc.cn
spring-cloud-starter-kubernetes-client-configspring-doc.cn
For development purposes, you can add cluster-reader permissions to your default service account. On a production system you’ll likely want to provide more granular permissions.spring-doc.cn
The following Role and RoleBinding are an example for namespaced permissions for the default account:spring-doc.cn
kind: Role
apiVersion: rbac.authorization.k8s.io/v1
metadata:
  namespace: YOUR-NAME-SPACE
rules:
  - apiGroups: [""]
    resources: ["configmaps", "pods", "services", "endpoints", "secrets"]
    verbs: ["get", "list", "watch"]
kind: RoleBinding
metadata:
subjects:
- kind: ServiceAccount
  apiGroup: ""
roleRef:
  kind: Role
  apiGroup: ""
