This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Cloud Kubernetes 3.2.0!spring-doc.cn
LoadBalancer for Kubernetes
This project includes Spring Cloud Load Balancer for load balancing based on either Kubernetes Endpoints or Kubernetes Service. To include it to your project add the following dependency. Fabric8 Implementationspring-doc.cn
<dependency>
    <artifactId>spring-cloud-starter-kubernetes-fabric8-loadbalancer</artifactId>
</dependency>
Kubernetes Java Client Implementationspring-doc.cn
<dependency>
    <artifactId>spring-cloud-starter-kubernetes-client-loadbalancer</artifactId>
</dependency>
There are two "modes" in which load balancer works: POD and SERVICE, denoted by the property (default being POD)spring-doc.cn
spring.cloud.kubernetes.loadbalancer.mode=SERVICE
spring.cloud.kubernetes.loadbalancer.mode=POD
In POD mode, we will use the DiscoveryClient to find all services that match your load balancer name. For example, if you have a configuration like this:spring-doc.cn
@LoadBalanced
WebClient.Builder client() {
	return WebClient.builder();
and issue a request to service-a using that WebClient, we will use service-a to call DiscoveryClient::getInstances with this value. Since this is using DiscoveryClient, all the configuration specific to it apply, which are explained in the relevant part of the documentation.spring-doc.cn
On the other hand, if you use SERVICE mode, things are a bit different, but closely resemble discovery client settings. For example, to answer the question in which namespace(s) to look for service(s) with name service-a, we will use one of the settings:spring-doc.cn
spring.cloud.kubernetes.discovery.all-namespaces
spring.cloud.kubernetes.discovery.namespaces
to either search in all-namespaces, or the so-called "selective namespaces". If none of the above are specified, Namespace Resolution kicks in.spring-doc.cn
Once we find all the services, we need to know what port to call them by. If the service in question has a single port defined, that is what we will use, no matter of its name. If there are no ports defined, this service will not be considered for load balancing and will be skipped.spring-doc.cn
If there are more then one ports defined, we will try to match its name to the value of the property (http by default):spring-doc.cn
spring.cloud.kubernetes.loadbalancer.portName
In case such a match is found, that port number will be used. Otherwise, the "first" port from the list will be used. This last option is non-deterministic and care must be taken.spring-doc.cn
Once we know the port, we know how to call that service. The URL will have the form:spring-doc.cn
service-a.<SERVICE_NAMESPACE>.svc.<DOMAIN>:<FOUND_PORT>
<SERVICE_NAMESPACE> is the namespace where the service resides, DOMAIN is the value of the property (by default it is equal to cluster.local):spring-doc.cn
spring.cloud.kubernetes.loadbalancer.clusterDomain
and <FOUND_PORT> is the port of the service that we have chosen described in the process above.spring-doc.cn
If a service needs to be accessed over HTTPS, you need to explicitly configure that. The rules for that are exactly the same as for the discovery implementation and can be found in the relevant part of the documentation regarding discovery-client.spring-doc.cn
