16. Troubleshooting
This section covers common problems that may arise when you use Spring Cloud Gateway.
16.1. Log Levels
The following loggers may contain valuable troubleshooting information at the DEBUG
and TRACE
levels:
org.springframework.cloud.gateway
org.springframework.http.server.reactive
org.springframework.web.reactive
org.springframework.boot.autoconfigure.web
reactor.netty
redisratelimiter
16.2. Wiretap
The Reactor Netty HttpClient
and HttpServer
can have wiretap enabled.
When combined with setting the reactor.netty
log level to DEBUG
or TRACE
, it enables the logging of information, such as headers and bodies sent and received across the wire.
To enable wiretap, set spring.cloud.gateway.httpserver.wiretap=true
or spring.cloud.gateway.httpclient.wiretap=true
for the HttpServer
and HttpClient
, respectively.
