9. TLS and SSL
The gateway can listen for requests on HTTPS by following the usual Spring server configuration. The following example shows how to do so:
Example 59. application.yml
server:
  ssl:
    enabled: true
    key-alias: scg
    key-store-password: scg1234
    key-store: classpath:scg-keystore.p12
    key-store-type: PKCS12
You can route gateway routes to both HTTP and HTTPS backends. If you are routing to an HTTPS backend, you can configure the gateway to trust all downstream certificates with the following configuration:
Example 60. application.yml
spring:
  cloud:
    gateway:
      httpclient:
        ssl:
          useInsecureTrustManager: true
Using an insecure trust manager is not suitable for production. For a production deployment, you can configure the gateway with a set of known certificates that it can trust with the following configuration:
Example 61. application.yml
spring:
  cloud:
    gateway:
      httpclient:
        ssl:
          trustedX509Certificates:
          - cert1.pem
          - cert2.pem
If the Spring Cloud Gateway is not provisioned with trusted certificates, the default trust store is used (which you can override by setting the javax.net.ssl.trustStore system property).
9.1. TLS Handshake
The gateway maintains a client pool that it uses to route to backends. When communicating over HTTPS, the client initiates a TLS handshake. A number of timeouts are associated with this handshake. You can configure these timeouts can be configured (defaults shown) as follows:
Example 62. application.yml
spring:
  cloud:
    gateway:
      httpclient:
        ssl:
          handshake-timeout-millis: 10000
          close-notify-flush-timeout-millis: 3000
          close-notify-read-timeout-millis: 0
APP信息
