15. Actuator API
The /gateway
actuator endpoint lets you monitor and interact with a Spring Cloud Gateway application.
To be remotely accessible, the endpoint has to be enabled and exposed over HTTP or JMX in the application properties.
The following listing shows how to do so:
management.endpoint.gateway.enabled=true # default value
management.endpoints.web.exposure.include=gateway
15.1. Verbose Actuator Format
A new, more verbose format has been added to Spring Cloud Gateway.
It adds more detail to each route, letting you view the predicates and filters associated with each route along with any configuration that is available.
The following example configures /actuator/gateway/routes
"predicate": "(Hosts: [**.addrequestheader.org] && Paths: [/headers], match trailing slash: true)",
"route_id": "add_request_header_test",
"filters": [
"[[AddResponseHeader X-Response-Default-Foo = 'Default-Bar'], order = 1]",
"[[AddRequestHeader X-Request-Foo = 'Bar'], order = 1]",
"[[PrefixPath prefix = '/httpbin'], order = 2]"
"uri": "lb://testservice",
"order": 0
This feature is enabled by default. To disable it, set the following property:
spring.cloud.gateway.actuator.verbose.enabled=false
This will default to true
in a future release.
15.2. Retrieving Route Filters
This section details how to retrieve route filters, including:
15.2.1. Global Filters
To retrieve the global filters applied to all routes, make a GET
request to /actuator/gateway/globalfilters
. The resulting response is similar to the following:
{ "org.springframework.cloud.gateway.filter.ReactiveLoadBalancerClientFilter@77856cc5": 10100, "org.springframework.cloud.gateway.filter.RouteToRequestUrlFilter@4f6fd101": 10000, "org.springframework.cloud.gateway.filter.NettyWriteResponseFilter@32d22650": -1, "org.springframework.cloud.gateway.filter.ForwardRoutingFilter@106459d9": 2147483647, "org.springframework.cloud.gateway.filter.NettyRoutingFilter@1fbd5e0": 2147483647, "org.springframework.cloud.gateway.filter.ForwardPathFilter@33a71d23": 0, "org.springframework.cloud.gateway.filter.AdaptCachedBodyGlobalFilter@135064ea": 2147483637, "org.springframework.cloud.gateway.filter.WebsocketRoutingFilter@23c05889": 2147483646 }
The response contains the details of the global filters that are in place.
For each global filter, there is a string representation of the filter object (for example, org.springframework.cloud.gateway.filter.ReactiveLoadBalancerClientFilter@77856cc5
) and the corresponding order in the filter chain.}
15.2.2. Route Filters
To retrieve the GatewayFilter
factories applied to routes, make a GET
request to /actuator/gateway/routefilters
{ "[AddRequestHeaderGatewayFilterFactory@570ed9c configClass = AbstractNameValueGatewayFilterFactory.NameValueConfig]": null, "[SecureHeadersGatewayFilterFactory@fceab5d configClass = Object]": null, "[SaveSessionGatewayFilterFactory@4449b273 configClass = Object]": null }
The response contains the details of the GatewayFilter
factories applied to any particular route.
For each factory there is a string representation of the corresponding object (for example, [SecureHeadersGatewayFilterFactory@fceab5d configClass = Object]
Note that the null
value is due to an incomplete implementation of the endpoint controller, because it tries to set the order of the object in the filter chain, which does not apply to a GatewayFilter
factory object.
15.3. Refreshing the Route Cache
To clear the routes cache, make a POST
request to /actuator/gateway/refresh
The request returns a 200 without a response body.
15.4. Retrieving the Routes Defined in the Gateway
To retrieve the routes defined in the gateway, make a GET
request to /actuator/gateway/routes
[{ "route_id": "first_route", "route_object": { "predicate": "org.springframework.cloud.gateway.handler.predicate.PathRoutePredicateFactory$$Lambda$432/1736826640@1e9d7e7d", "filters": [ "OrderedGatewayFilter{delegate=org.springframework.cloud.gateway.filter.factory.PreserveHostHeaderGatewayFilterFactory$$Lambda$436/674480275@6631ef72, order=0}" ] }, "order": 0 }, { "route_id": "second_route", "route_object": { "predicate": "org.springframework.cloud.gateway.handler.predicate.PathRoutePredicateFactory$$Lambda$432/1736826640@cd8d298", "filters": [] }, "order": 0 }]
The response contains the details of all the routes defined in the gateway. The following table describes the structure of each element (each is a route) of the response:
Path | Type | Description |
String |
The route ID. |
Object |
The route predicate. |
Array |
The |
Number |
The route order. |
15.5. Retrieving Information about a Particular Route
To retrieve information about a single route, make a GET
request to /actuator/gateway/routes/{id}
(for example, /actuator/gateway/routes/first_route
{ "id": "first_route", "predicates": [{ "name": "Path", "args": {"_genkey_0":"/first"} }], "filters": [], "uri": "https://www.uri-destination.org", "order": 0 }]
The following table describes the structure of the response:
String |
The route ID. |
Array |
The collection of route predicates. Each item defines the name and the arguments of a given predicate. |
Array |
The collection of filters applied to the route. |
String |
The destination URI of the route. |
Number |
The route order. |
15.6. Creating and Deleting a Particular Route
To create a route, make a POST
request to /gateway/routes/{id_route_to_create}
with a JSON body that specifies the fields of the route (see Retrieving Information about a Particular Route).
To delete a route, make a DELETE
request to /gateway/routes/{id_route_to_delete}
15.7. Recap: The List of All endpoints
The folloiwng table below summarizes the Spring Cloud Gateway actuator endpoints (note that each endpoint has /actuator/gateway
as the base-path):
ID | HTTP Method | Description |
GET |
Displays the list of global filters applied to the routes. |
GET |
Displays the list of |
POST |
Clears the routes cache. |
GET |
Displays the list of routes defined in the gateway. |
GET |
Displays information about a particular route. |
POST |
Adds a new route to the gateway. |
DELETE |
Removes an existing route from the gateway. |
