此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 spring-cloud-contract 4.1.5spring-doc.cadn.net.cn
Stub Runner JUnit 规则和 Stub Runner JUnit5 扩展
Stub Runner 附带一个 JUnit 规则,允许您下载和运行给定的 stub group 和工件 ID,如下例所示:spring-doc.cadn.net.cn
@ClassRule
public static StubRunnerRule rule = new StubRunnerRule().repoRoot(repoRoot())
	.stubsMode(StubRunnerProperties.StubsMode.REMOTE)
	.downloadStub("org.springframework.cloud.contract.verifier.stubs", "loanIssuance")
	.downloadStub("org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer");
@BeforeClass
@AfterClass
public static void setupProps() {
	System.clearProperty("stubrunner.repository.root");
	System.clearProperty("stubrunner.classifier");
一个StubRunnerExtension也可用于 JUnit 5。StubRunnerRuleStubRunnerExtension以非常相似的方式工作。在规则或扩展名 调用,则 Stub Runner 会连接到您的 Maven 存储库,并且对于给定的 依赖项尝试:spring-doc.cadn.net.cn
Stub Runner 使用 Eclipse Aether 机制下载 Maven 依赖项。 查看他们的文档以获取更多信息。spring-doc.cadn.net.cn
由于StubRunnerRuleStubRunnerExtension实现StubFinder,他们让 您可以找到 Started Stubs,如下例所示:spring-doc.cadn.net.cn
import java.net.URL;
import java.util.Collection;
import java.util.Map;
import org.springframework.cloud.contract.spec.Contract;
 * Contract for finding registered stubs.
 * @author Marcin Grzejszczak
public interface StubFinder extends StubTrigger {
	 * For the given groupId and artifactId tries to find the matching URL of the running
	 * stub.
	 * @param groupId - might be null. In that case a search only via artifactId takes
	 * place
	 * @param artifactId - artifact id of the stub
	 * @return URL of a running stub or throws exception if not found
	 * @throws StubNotFoundException in case of not finding a stub
	URL findStubUrl(String groupId, String artifactId) throws StubNotFoundException;
	 * For the given Ivy notation {@code [groupId]:artifactId:[version]:[classifier]}
	 * tries to find the matching URL of the running stub. You can also pass only
	 * {@code artifactId}.
	 * @param ivyNotation - Ivy representation of the Maven artifact
	URL findStubUrl(String ivyNotation) throws StubNotFoundException;
	 * @return all running stubs
	RunningStubs findAllRunningStubs();
	 * @return the list of Contracts
	Map<StubConfiguration, Collection<Contract>> getContracts();
以下示例提供了有关使用 Stub Runner 的更多详细信息:spring-doc.cadn.net.cn
斯波克
@ClassRule
@Shared
		.repoRoot(StubRunnerRuleSpec.getResource("/m2repo/repository").toURI().toString())
		.withMappingsOutputFolder("target/outputmappingsforrule")
def 'should start WireMock servers'() {
	expect: 'WireMocks are running'
		rule.findStubUrl('org.springframework.cloud.contract.verifier.stubs', 'loanIssuance') != null
		rule.findStubUrl('loanIssuance') != null
		rule.findStubUrl('loanIssuance') == rule.findStubUrl('org.springframework.cloud.contract.verifier.stubs', 'loanIssuance')
		rule.findStubUrl('org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer') != null
	and:
		rule.findAllRunningStubs().isPresent('loanIssuance')
		rule.findAllRunningStubs().isPresent('org.springframework.cloud.contract.verifier.stubs', 'fraudDetectionServer')
		rule.findAllRunningStubs().isPresent('org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer')
	and: 'Stubs were registered'
		"${rule.findStubUrl('loanIssuance').toString()}/name".toURL().text == 'loanIssuance'
		"${rule.findStubUrl('fraudDetectionServer').toString()}/name".toURL().text == 'fraudDetectionServer'
def 'should output mappings to output folder'() {
	when:
		def url = rule.findStubUrl('fraudDetectionServer')
	then:
		new File("target/outputmappingsforrule", "fraudDetectionServer_${url.port}").exists()
朱尼特 4
@Test
public void should_start_wiremock_servers() throws Exception {
	// expect: 'WireMocks are running'
	then(rule.findStubUrl("org.springframework.cloud.contract.verifier.stubs", "loanIssuance")).isNotNull();
	then(rule.findStubUrl("loanIssuance")).isNotNull();
		.isEqualTo(rule.findStubUrl("org.springframework.cloud.contract.verifier.stubs", "loanIssuance"));
	then(rule.findStubUrl("org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer")).isNotNull();
	// and:
	then(rule.findAllRunningStubs().isPresent("loanIssuance")).isTrue();
		.isPresent("org.springframework.cloud.contract.verifier.stubs", "fraudDetectionServer")).isTrue();
		.isPresent("org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer")).isTrue();
	// and: 'Stubs were registered'
	then(httpGet(rule.findStubUrl("loanIssuance").toString() + "/name")).isEqualTo("loanIssuance");
	then(httpGet(rule.findStubUrl("fraudDetectionServer").toString() + "/name")).isEqualTo("fraudDetectionServer");
朱尼特 5
// Visible for Junit
@RegisterExtension
static StubRunnerExtension stubRunnerExtension = new StubRunnerExtension().repoRoot(repoRoot())
	.withMappingsOutputFolder("target/outputmappingsforrule");
@BeforeAll
@AfterAll
private static String repoRoot() {
	try {
		return StubRunnerRuleJUnitTest.class.getResource("/m2repo/repository/").toURI().toString();
	catch (Exception e) {
		return "";
有关更多信息,请参阅 JUnit 和 Spring 的通用属性 如何应用 Stub Runner 的全局配置。spring-doc.cadn.net.cn
要将 JUnit 规则或 JUnit 5 扩展与消息传递一起使用,您必须提供MessageVerifierSenderMessageVerifierReceiver规则生成器的界面(例如rule.messageVerifierSender(new MyMessageVerifierSender())). 如果不这样做,则每当尝试发送消息时,都会引发异常。
Maven 设置
存根下载程序遵循其他本地存储库文件夹的 Maven 设置。 当前不考虑存储库和配置文件的身份验证详细信息。 因此,您需要使用上述属性来指定它。spring-doc.cadn.net.cn
提供固定端口
您还可以在固定端口上运行存根。您可以通过两种不同的方式来实现。 一种是在 properties 中传递,另一种是使用 Fluent API JUnit 规则。spring-doc.cadn.net.cn
Fluent API
使用StubRunnerRuleStubRunnerExtension,您可以添加要下载的存根 然后传递最后下载的存根的端口。以下示例显示了如何执行此作:spring-doc.cadn.net.cn
@ClassRule
	.withPort(35465)
	.downloadStub("org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer:35466");
@BeforeClass
@AfterClass
对于前面的示例,以下测试有效:spring-doc.cadn.net.cn
then(rule.findStubUrl("loanIssuance")).isEqualTo(URI.create("http://localhost:35465").toURL());
then(rule.findStubUrl("fraudDetectionServer")).isEqualTo(URI.create("http://localhost:35466").toURL());
带弹簧的短管流道
Stub Runner with Spring 设置 Stub Runner 项目的 Spring 配置。spring-doc.cadn.net.cn
通过在配置文件中提供存根列表,Stub Runner 会自动下载 并在 WireMock 中注册选定的存根。spring-doc.cadn.net.cn
如果你想找到你的存根依赖项的 URL,你可以自动装配StubFinder接口和使用 其方法,如下所示:spring-doc.cadn.net.cn
@SpringBootTest(classes = Config, properties = [" stubrunner.cloud.enabled=false",
		'foo=${stubrunner.runningstubs.fraudDetectionServer.port}',
		'fooWithGroup=${stubrunner.runningstubs.org.springframework.cloud.contract.verifier.stubs.fraudDetectionServer.port}'])
@AutoConfigureStubRunner(mappingsOutputFolder = "target/outputmappings/",
		httpServerStubConfigurer = HttpsForFraudDetection)
@ActiveProfiles("test")
class StubRunnerConfigurationSpec {
	@Autowired
	StubFinder stubFinder
	@Autowired
	Environment environment
	@StubRunnerPort("fraudDetectionServer")
	int fraudDetectionServerPort
	@StubRunnerPort("org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer")
	int fraudDetectionServerPortWithGroupId
	@Value('${foo}')
	Integer foo
	@BeforeAll
	static void setupSpec() {
		WireMockHttpServerStubAccessor.clear()
	@AfterAll
	static void cleanupSpec() {
		setupSpec()
	@Test
	void 'should mark all ports as random'() {
		expect:
		WireMockHttpServerStubAccessor.everyPortRandom()
	@Test
	void 'should start WireMock servers'() {
		assert stubFinder.findStubUrl('org.springframework.cloud.contract.verifier.stubs', 'loanIssuance') != null
		assert stubFinder.findStubUrl('loanIssuance') != null
		assert stubFinder.findStubUrl('loanIssuance') == stubFinder.findStubUrl('org.springframework.cloud.contract.verifier.stubs', 'loanIssuance')
		assert stubFinder.findStubUrl('loanIssuance') == stubFinder.findStubUrl('org.springframework.cloud.contract.verifier.stubs:loanIssuance')
		assert stubFinder.findStubUrl('org.springframework.cloud.contract.verifier.stubs:loanIssuance:0.0.1-SNAPSHOT') == stubFinder.findStubUrl('org.springframework.cloud.contract.verifier.stubs:loanIssuance:0.0.1-SNAPSHOT:stubs')
		assert stubFinder.findStubUrl('org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer') != null
		and:
		assert stubFinder.findAllRunningStubs().isPresent('loanIssuance')
		assert stubFinder.findAllRunningStubs().isPresent('org.springframework.cloud.contract.verifier.stubs', 'fraudDetectionServer')
		assert stubFinder.findAllRunningStubs().isPresent('org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer')
		assert "${stubFinder.findStubUrl('loanIssuance').toString()}/name".toURL().text == 'loanIssuance'
		assert "${stubFinder.findStubUrl('fraudDetectionServer').toString()}/name".toURL().text == 'fraudDetectionServer'
		and: 'Fraud Detection is an HTTPS endpoint'
		assert stubFinder.findStubUrl('fraudDetectionServer').toString().startsWith("https")
	@Test
	void 'should throw an exception when stub is not found'() {
		when:
			BDDAssertions.thenThrownBy(() -> stubFinder.findStubUrl('nonExistingService')).isInstanceOf(StubNotFoundException)
		when:
			BDDAssertions.thenThrownBy(() -> stubFinder.findStubUrl('nonExistingGroupId', 'nonExistingArtifactId'))
	@Test
	void 'should register started servers as environment variables'() {
		expect:
		assert environment.getProperty("stubrunner.runningstubs.loanIssuance.port") != null
		assert stubFinder.findAllRunningStubs().getPort("loanIssuance") == (environment.getProperty("stubrunner.runningstubs.loanIssuance.port") as Integer)
		and:
		assert environment.getProperty("stubrunner.runningstubs.fraudDetectionServer.port") != null
		assert stubFinder.findAllRunningStubs().getPort("fraudDetectionServer") == (environment.getProperty("stubrunner.runningstubs.fraudDetectionServer.port") as Integer)
		and:
		assert stubFinder.findAllRunningStubs().getPort("fraudDetectionServer") == (environment.getProperty("stubrunner.runningstubs.org.springframework.cloud.contract.verifier.stubs.fraudDetectionServer.port") as Integer)
	@Test
	void 'should be able to interpolate a running stub in the passed test property'() {
		given:
		int fraudPort = stubFinder.findAllRunningStubs().getPort("fraudDetectionServer")
		expect:
		assert fraudPort > 0
		assert environment.getProperty("foo", Integer) == fraudPort
		assert environment.getProperty("fooWithGroup", Integer) == fraudPort
		assert foo == fraudPort
//	@Issue("#573")
	@Test
	void 'should be able to retrieve the port of a running stub via an annotation'() {
		given:
		expect:
		assert fraudDetectionServerPort == fraudPort
		assert fraudDetectionServerPortWithGroupId == fraudPort
	@Test
	void 'should dump all mappings to a file'() {
		when:
		def url = stubFinder.findStubUrl("fraudDetectionServer")
		then:
		assert new File("target/outputmappings/", "fraudDetectionServer_${url.port}").exists()
	@EnableAutoConfiguration
	static class Config {}
	@CompileStatic
	static class HttpsForFraudDetection extends WireMockHttpServerStubConfigurer {
		private static final Log log = LogFactory.getLog(HttpsForFraudDetection)
		WireMockConfiguration configure(WireMockConfiguration httpStubConfiguration, HttpServerStubConfiguration httpServerStubConfiguration) {
			if (httpServerStubConfiguration.stubConfiguration.artifactId == "fraudDetectionServer") {
				int httpsPort = TestSocketUtils.findAvailableTcpPort()
				log.info("Will set HTTPs port [" + httpsPort + "] for fraud detection server")
				return httpStubConfiguration
						.httpsPort(httpsPort)
这样做取决于以下配置文件:spring-doc.cadn.net.cn
stubrunner:
  repositoryRoot: classpath:m2repo/repository/
  ids:
    - org.springframework.cloud.contract.verifier.stubs:loanIssuance
    - org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer
    - org.springframework.cloud.contract.verifier.stubs:bootService
  stubs-mode: remote
除了使用属性,您还可以使用@AutoConfigureStubRunner. 以下示例通过在 annotation 上设置值来获得相同的结果:spring-doc.cadn.net.cn
@AutoConfigureStubRunner(ids = ["org.springframework.cloud.contract.verifier.stubs:loanIssuance",
 "org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer",
 "org.springframework.cloud.contract.verifier.stubs:bootService"] ,
stubsMode = StubRunnerProperties.StubsMode.REMOTE ,
repositoryRoot = "classpath:m2repo/repository/" )
Stub Runner Spring 按以下方式注册环境变量 对于每个已注册的 WireMock 服务器。以下示例显示了com.example:thing1com.example:thing2:spring-doc.cadn.net.cn
您可以在代码中引用这些值。spring-doc.cadn.net.cn
您还可以使用@StubRunnerPort注解注入正在运行的存根的端口。 注解的值可以是groupid:artifactid或仅artifactid. 以下示例显示了com.example:thing1com.example:thing2.spring-doc.cadn.net.cn
@StubRunnerPort("thing1")
int thing1Port;
@StubRunnerPort("com.example:thing2")
int thing2Port;
