此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 spring-cloud-contract 4.1.5spring-doc.cadn.net.cn
合约 DSL
Spring Cloud Contract 支持以下语言编写的 DSL:spring-doc.cadn.net.cn
Spring Cloud Contract 支持在单个文件中定义多个 Contract (在 Groovy 中返回一个列表而不是单个 Contract )。
以下示例显示了 Contract 定义:spring-doc.cadn.net.cn
槽的
org.springframework.cloud.contract.spec.Contract.make {
	request {
		method 'PUT'
		url '/api/12'
		headers {
			header 'Content-Type': 'application/vnd.org.springframework.cloud.contract.verifier.twitter-places-analyzer.v1+json'
		body '''\
		"created_at": "Sat Jul 26 09:38:57 +0000 2014",
		"id": 492967299297845248,
		"id_str": "492967299297845248",
		"text": "Gonna see you at Warsaw",
		"place":
			"attributes":{},
			"bounding_box":
				"coordinates":
						[-77.119759,38.791645],
						[-76.909393,38.791645],
						[-76.909393,38.995548],
						[-77.119759,38.995548]
				"type":"Polygon"
			"country":"United States",
			"country_code":"US",
			"full_name":"Washington, DC",
			"id":"01fbe706f872cb32",
			"name":"Washington",
			"place_type":"city",
			"url": "https://api.twitter.com/1/geo/id/01fbe706f872cb32.json"
	response {
		status OK()
YAML
description: Some description
priority: 8
ignored: true
request:
  url: /foo
  queryParameters:
    a: b
    b: c
  method: PUT
  headers:
    foo: bar
    fooReq: baz
  body:
    foo: bar
  matchers:
    body:
      - path: $.foo
        type: by_regex
        value: bar
    headers:
      - key: foo
        regex: bar
response:
  status: 200
  headers:
    foo2: bar
    foo3: foo33
    fooRes: baz
  body:
    foo2: bar
    foo3: baz
    nullValue: null
  matchers:
    body:
      - path: $.foo2
        type: by_regex
        value: bar
      - path: $.foo3
        type: by_command
        value: executeMe($it)
      - path: $.nullValue
        type: by_null
        value: null
    headers:
      - key: foo2
        regex: bar
      - key: foo3
        command: andMeToo($it)
Java
import java.util.Collection;
import java.util.Collections;
import java.util.function.Supplier;
import org.springframework.cloud.contract.spec.Contract;
import org.springframework.cloud.contract.verifier.util.ContractVerifierUtil;
class contract_rest implements Supplier<Collection<Contract>> {
	public Collection<Contract> get() {
		return Collections.singletonList(Contract.make(c -> {
			c.description("Some description");
			c.name("some name");
			c.priority(8);
			c.ignored();
			c.request(r -> {
				r.url("/foo", u -> {
					u.queryParameters(q -> {
						q.parameter("a", "b");
						q.parameter("b", "c");
				r.method(r.PUT());
				r.headers(h -> {
					h.header("foo", r.value(r.client(r.regex("bar")), r.server("bar")));
					h.header("fooReq", "baz");
				r.body(ContractVerifierUtil.map().entry("foo", "bar"));
				r.bodyMatchers(m -> {
					m.jsonPath("$.foo", m.byRegex("bar"));
			c.response(r -> {
				r.fixedDelayMilliseconds(1000);
				r.status(r.OK());
				r.headers(h -> {
					h.header("foo2", r.value(r.server(r.regex("bar")), r.client("bar")));
					h.header("foo3", r.value(r.server(r.execute("andMeToo($it)")), r.client("foo33")));
					h.header("fooRes", "baz");
				r.body(ContractVerifierUtil.map().entry("foo2", "bar").entry("foo3", "baz").entry("nullValue", null));
					m.jsonPath("$.foo2", m.byRegex("bar"));
					m.jsonPath("$.foo3", m.byCommand("executeMe($it)"));
					m.jsonPath("$.nullValue", m.byNull());
Kotlin
import org.springframework.cloud.contract.spec.ContractDsl.Companion.contract
import org.springframework.cloud.contract.spec.withQueryParameters
contract {
	name = "some name"
	description = "Some description"
	priority = 8
	ignored = true
	request {
		url = url("/foo") withQueryParameters  {
			parameter("a", "b")
			parameter("b", "c")
		method = PUT
		headers {
			header("foo", value(client(regex("bar")), server("bar")))
		body = body(mapOf("foo" to "bar"))
		bodyMatchers {
			jsonPath("$.foo", byRegex("bar"))
	response {
		delay = fixedMilliseconds(1000)
		status = OK
		headers {
			header("foo2", value(server(regex("bar")), client("bar")))
			header("foo3", value(server(execute("andMeToo(\$it)")), client("foo33")))
		body = body(mapOf(
				"foo" to "bar",
				"foo3" to "baz",
				"nullValue" to null
		bodyMatchers {
			jsonPath("$.foo2", byRegex("bar"))
			jsonPath("$.foo3", byCommand("executeMe(\$it)"))
			jsonPath("$.nullValue", byNull)
您可以使用以下独立的 Maven 命令将合同编译为存根映射:spring-doc.cadn.net.cn
mvn org.springframework.cloud:spring-cloud-contract-maven-plugin:convert
Groovy 中的 Contract DSL
如果您不熟悉 Groovy,请不要担心。您可以在 Groovy DSL 文件。spring-doc.cadn.net.cn
如果您决定用 Groovy 编写合约,如果您还没有使用 Groovy,请不要惊慌 以前。实际上并不需要了解该语言,因为 Contract DSL 只使用 它的一小部分(仅 Literals、Method Calls 和 Closure)。此外,DSL 是静态的 typed,使其无需任何 DSL 本身知识即可程序员可读。spring-doc.cadn.net.cn
请记住,在 Groovy 合约文件中,您必须提供完整的 限定名称设置为Contractclass 和makestatic imports(例如org.springframework.cloud.spec.Contract.make { …​ }.您还可以将导入 这Contract类 (import org.springframework.cloud.spec.Contract),然后调用Contract.make { …​ }.
Java 中的合约 DSL
要在 Java 中编写合约定义,您需要创建一个类,该类实现Supplier<Contract>interface (对于单个合约)或Supplier<Collection<Contract>>(对于多个合同)。spring-doc.cadn.net.cn
您还可以在src/test/java(例如,src/test/java/contracts),这样就不必修改项目的 Classpath 了。在这种情况下,您必须为 Spring Cloud Contract 插件提供 Contract 定义的新位置。spring-doc.cadn.net.cn
以下示例(在 Maven 和 Gradle 中)在src/test/java:spring-doc.cadn.net.cn
Maven 系列
<plugin>
    <artifactId>spring-cloud-contract-maven-plugin</artifactId>
    <version>${spring-cloud-contract.version}</version>
    <extensions>true</extensions>
    <configuration>
        <contractsDirectory>src/test/java/contracts</contractsDirectory>
    </configuration>
</plugin>
Gradle
contracts {
	contractsDslDir = new File(project.rootDir, "src/test/java/contracts")
Kotlin 中的合约 DSL
要开始使用 Kotlin 编写合约,您需要从一个(新创建的)Kotlin 脚本文件 (.kts). 与 Java DSL 一样,您可以将 Contract 放在您选择的任何目录中。 默认情况下,Maven 插件将查看src/test/resources/contracts目录和 Gradle 插件将 看看src/contractTest/resources/contracts目录。spring-doc.cadn.net.cn
从 3.0.0 开始,Gradle 插件也将查看遗留的 目录src/test/resources/contracts用于迁移目的。在此目录中找到 Contract 时,会显示一条警告 将在您的构建过程中记录。
您需要显式传递spring-cloud-contract-spec-kotlin依赖项添加到您的项目插件设置中。 以下示例(在 Maven 和 Gradle 中)展示了如何做到这一点:spring-doc.cadn.net.cn
Maven 系列
<plugin>
    <configuration>
        <!-- some config -->
    </configuration>
    <dependencies>
        <dependency>
            <artifactId>spring-cloud-contract-spec-kotlin</artifactId>
        </dependency>
    </dependencies>
</plugin>
<dependencies>
        <!-- Remember to add this for the DSL support in the IDE and on the consumer side -->
        <dependency>
            <scope>test</scope>
        </dependency>
</dependencies>
Gradle
buildscript {
    repositories {
	dependencies {
		classpath "org.springframework.cloud:spring-cloud-contract-gradle-plugin:$\{scContractVersion}"
dependencies {
    // Remember to add this for the DSL support in the IDE and on the consumer side
    testImplementation "org.springframework.cloud:spring-cloud-contract-spec-kotlin"
    // Kotlin versions are very particular down to the patch version. The <kotlin_version> needs to be the same as you have imported for your project.
    testImplementation "org.jetbrains.kotlin:kotlin-scripting-compiler-embeddable:<kotlin_version>"
请记住,在 Kotlin 脚本文件中,您必须为ContractDSL类。 通常,您将按如下方式使用其 contract 函数:org.springframework.cloud.contract.spec.ContractDsl.contract { …​ }. 您还可以提供对contract函数 (import org.springframework.cloud.contract.spec.ContractDsl.Companion.contract),然后调用contract { …​ }.
YAML 中的合约 DSL
要查看 YAML 协定的架构,请访问 YML 架构页面。spring-doc.cadn.net.cn
局限性
对验证 JSON 数组大小的支持是实验性的。如果需要帮助, 要启用它,请将以下 System 属性的值设置为true:spring.cloud.contract.verifier.assert.size.默认情况下,此功能设置为false. 您还可以设置assertJsonSize属性。
由于 JSON 结构可以具有任何形式,因此可能无法对其进行解析 正确地使用 Groovy DSL 和value(consumer(…​), producer(…​))表示法GString.那 是您应该使用 Groovy Map 表示法的原因。
一个文件中的多个合同
您可以在一个文件中定义多个合同。这样的合约可能类似于 以下示例:spring-doc.cadn.net.cn
槽的
	Contract.make {
		name("should post a user")
		request {
			method 'POST'
			url('/users/1')
		response {
			status OK()
	Contract.make {
		request {
			method 'POST'
			url('/users/2')
		response {
			status OK()
YAML
name: should post a user
request:
  method: POST
  url: /users/1
response:
  status: 200
request:
  method: POST
  url: /users/2
response:
  status: 200
request:
  method: POST
  url: /users/3
response:
  status: 200
Java
class contract implements Supplier<Collection<Contract>> {
		return Arrays.asList(
            	c.name("should post a user");
            }), Contract.make(c -> {
Kotlin
arrayOf(
    contract {
    contract {
    contract {
在前面的示例中,一个合约具有name字段,而另一个则没有。这 导致生成两个测试,如下所示:spring-doc.cadn.net.cn
import com.example.TestBase;
import com.jayway.jsonpath.DocumentContext;
import com.jayway.jsonpath.JsonPath;
import com.jayway.restassured.module.mockmvc.specification.MockMvcRequestSpecification;
import com.jayway.restassured.response.ResponseOptions;
import org.junit.Test;
import static com.jayway.restassured.module.mockmvc.RestAssuredMockMvc.*;
import static com.toomuchcoding.jsonassert.JsonAssertion.assertThatJson;
import static org.assertj.core.api.Assertions.assertThat;
public class V1Test extends TestBase {
	@Test
	public void validate_should_post_a_user() throws Exception {
		// given:
			MockMvcRequestSpecification request = given();
		// when:
			ResponseOptions response = given().spec(request)
					.post("/users/1");
		// then:
			assertThat(response.statusCode()).isEqualTo(200);
	@Test
	public void validate_withList_1() throws Exception {
		// given:
		// when:
					.post("/users/2");
		// then:
请注意,对于具有name字段中,生成的测试方法名为validate_should_post_a_user.没有namefield 调用validate_withList_1.它对应于文件的名称WithList.groovy和 列表中合约的索引。spring-doc.cadn.net.cn
生成的存根如以下示例所示:spring-doc.cadn.net.cn
should post a user.json
1_WithList.json
第一个文件获取了name参数。第二个 获取了合约文件的名称 (WithList.groovy) 前缀为索引(在此 case,则合约的索引为1在文件的合同列表中)。spring-doc.cadn.net.cn
为您的合约命名要好得多,因为这样做会使 您的测试更有意义。
有状态合约
有状态合同(也称为场景)是应该读取的合同定义 挨次。这在以下情况下可能很有用:spring-doc.cadn.net.cn
  • 您希望以精确定义的顺序调用合约,因为您使用 Spring Cloud Contract 来测试您的有状态应用程序。spring-doc.cadn.net.cn
我们真的不鼓励你这样做,因为 Contract 测试应该是无状态的。
要创建有状态合约(或场景),您需要 在创建合同时使用正确的命名约定。约定 要求包含订单号,后跟下划线。这无论如何都有效 了解您是使用 YAML 还是 Groovy。下面的清单显示了一个示例:spring-doc.cadn.net.cn
my_contracts_dir\
  scenario1\
    1_login.groovy
    2_showCart.groovy
    3_logout.groovy
这样的树会导致 Spring Cloud Contract Verifier 生成 WireMock 的场景,其中包含 名称scenario1以及以下三个步骤:spring-doc.cadn.net.cn
  1. login,标记为Started指向...spring-doc.cadn.net.cn
  2. showCart,标记为Step1指向...spring-doc.cadn.net.cn
  3. logout,标记为Step2(这将关闭方案)。spring-doc.cadn.net.cn
您可以在 https://wiremock.org/docs/stateful-behaviour/ 中找到有关 WireMock 方案的更多详细信息。spring-doc.cadn.net.cn
