This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Cloud Commons 4.2.1! |
Spring Cloud Commons: Common Abstractions
Patterns such as service discovery, load balancing, and circuit breakers lend themselves to a common abstraction layer that can be consumed by all Spring Cloud clients, independent of the implementation (for example, discovery with Eureka or Consul).
The @EnableDiscoveryClient
Annotation
Spring Cloud Commons provides the @EnableDiscoveryClient
annotation.
This looks for implementations of the DiscoveryClient
and ReactiveDiscoveryClient
interfaces with META-INF/spring.factories
Implementations of the discovery client add a configuration class to spring.factories
under the org.springframework.cloud.client.discovery.EnableDiscoveryClient
key.
Examples of DiscoveryClient
implementations include Spring Cloud Netflix Eureka, Spring Cloud Consul Discovery, and Spring Cloud Zookeeper Discovery.
Spring Cloud will provide both the blocking and reactive service discovery clients by default.
You can disable the blocking and/or reactive clients easily by setting spring.cloud.discovery.blocking.enabled=false
or spring.cloud.discovery.reactive.enabled=false
To completely disable service discovery you just need to set spring.cloud.discovery.enabled=false
By default, implementations of DiscoveryClient
auto-register the local Spring Boot server with the remote discovery server.
This behavior can be disabled by setting autoRegister=false
in @EnableDiscoveryClient
@EnableDiscoveryClient is no longer required.
You can put a DiscoveryClient implementation on the classpath to cause the Spring Boot application to register with the service discovery server.
Health Indicators
Commons auto-configures the following Spring Boot health indicators.
DiscoveryClientHealthIndicator
This health indicator is based on the currently registered DiscoveryClient
implementation.
To disable entirely, set
spring.cloud.discovery.client.health-indicator.enabled=false
To disable the description field, set
spring.cloud.discovery.client.health-indicator.include-description=false
. Otherwise, it can bubble up as thedescription
of the rolled upHealthIndicator
To disable service retrieval, set
spring.cloud.discovery.client.health-indicator.use-services-query=false
. By default, the indicator invokes the client’sgetServices
method. In deployments with many registered services it may too costly to retrieve all services during every check. This will skip the service retrieval and instead use the client’sprobe
method.
Ordering DiscoveryClient
instances
DiscoveryClient
interface extends Ordered
. This is useful when using multiple discovery
clients, as it allows you to define the order of the returned discovery clients, similar to
how you can order the beans loaded by a Spring application. By default, the order of any DiscoveryClient
is set to
0
. If you want to set a different order for your custom DiscoveryClient
implementations, you just need to override
the getOrder()
method so that it returns the value that is suitable for your setup. Apart from this, you can use
properties to set the order of the DiscoveryClient
implementations provided by Spring Cloud, among others ConsulDiscoveryClient
, EurekaDiscoveryClient
and
ZookeeperDiscoveryClient
. In order to do it, you just need to set the
spring.cloud.{clientIdentifier}.discovery.order
(or eureka.client.order
for Eureka) property to the desired value.
SimpleDiscoveryClient
If there is no Service-Registry-backed DiscoveryClient
in the classpath, SimpleDiscoveryClient
instance, that uses properties to get information on service and instances, will be used.
The information about the available instances should be passed to via properties in the following format:
spring.cloud.discovery.client.simple.instances.service1[0].uri=http://s11:8080
, where
is the common prefix, then service1
stands
for the ID of the service in question, while [0]
indicates the index number of the instance
(as visible in the example, indexes start with 0
), and then the value of uri
is
the actual URI under which the instance is available.
ServiceRegistry
Commons now provides a ServiceRegistry
interface that provides methods such as register(Registration)
and deregister(Registration)
, which let you provide custom registered services.
Registration
is a marker interface.
The following example shows the ServiceRegistry
in use:
@EnableDiscoveryClient(autoRegister=false)
public class MyConfiguration {
private ServiceRegistry registry;
public MyConfiguration(ServiceRegistry registry) {
this.registry = registry;
// called through some external process, such as an event or a custom actuator endpoint
public void register() {
Registration registration = constructRegistration();
this.registry.register(registration);
Each ServiceRegistry
implementation has its own Registry
implementation.
ZookeeperRegistration
used withZookeeperServiceRegistry
EurekaRegistration
used withEurekaServiceRegistry
ConsulRegistration
used withConsulServiceRegistry
If you are using the ServiceRegistry
interface, you are going to need to pass the
correct Registry
implementation for the ServiceRegistry
implementation you
are using.
ServiceRegistry Auto-Registration
By default, the ServiceRegistry
implementation auto-registers the running service.
To disable that behavior, you can set:
* @EnableDiscoveryClient(autoRegister=false)
to permanently disable auto-registration.
* spring.cloud.service-registry.auto-registration.enabled=false
to disable the behavior through configuration.
ServiceRegistry Auto-Registration Events
There are two events that will be fired when a service auto-registers. The first event, called
InstancePreRegisteredEvent
, is fired before the service is registered. The second
event, called InstanceRegisteredEvent
, is fired after the service is registered. You can register an
ApplicationListener
(s) to listen to and react to these events.
These events will not be fired if the spring.cloud.service-registry.auto-registration.enabled property is set to false .
Service Registry Actuator Endpoint
Spring Cloud Commons provides a /serviceregistry
actuator endpoint.
This endpoint relies on a Registration
bean in the Spring Application Context.
Calling /serviceregistry
with GET returns the status of the Registration
Using POST to the same endpoint with a JSON body changes the status of the current Registration
to the new value.
The JSON body has to include the status
field with the preferred value.
Please see the documentation of the ServiceRegistry
implementation you use for the allowed values when updating the status and the values returned for the status.
For instance, Eureka’s supported statuses are UP
, DOWN
, OUT_OF_SERVICE
, and UNKNOWN
Spring RestTemplate as a LoadBalancer Client
You can configure a RestTemplate
to use a Load-balancer client.
To create a load-balanced RestTemplate
, create a RestTemplate
and use the @LoadBalanced
qualifier, as the following example shows:
@LoadBalanced
RestTemplate restTemplate() {
return new RestTemplate();
public class MyClass {
@Autowired
private RestTemplate restTemplate;
public String doOtherStuff() {
String result = restTemplate.getForObject("http://stores/stores", String.class);
return result;
A RestTemplate bean is no longer created through auto-configuration.
Individual applications must create it.
The URI needs to use a virtual host name (that is, a service name, not a host name).
The BlockingLoadBalancerClient
is used to create a full physical address.
To use a load-balanced RestTemplate , you need to have a Spring Cloud LoadBalancer implementation in your classpath.
Add Spring Cloud LoadBalancer starter to your project in order to use it.
Multiple RestTemplate Objects
If you want a RestTemplate
that is not load-balanced, create a RestTemplate
bean and inject it.
To access the load-balanced RestTemplate
, use the @LoadBalanced
qualifier when you create your @Bean
@LoadBalanced
RestTemplate loadBalanced() {
@Primary
@Autowired
@Autowired
@LoadBalanced
private RestTemplate loadBalanced;
return loadBalanced.getForObject("http://stores/stores", String.class);
public String doStuff() {
return restTemplate.getForObject("http://example.com", String.class);
Notice the use of the @Primary annotation on the plain RestTemplate declaration in the preceding example to disambiguate the unqualified @Autowired injection.
If you see errors such as java.lang.IllegalArgumentException: Can not set org.springframework.web.client.RestTemplate field com.my.app.Foo.restTemplate to com.sun.proxy.$Proxy89 , try injecting RestOperations or setting spring.aop.proxyTargetClass=true .
Spring RestClient as a LoadBalancer Client
You can configure a RestClient
To create a load-balanced RestClient
, create a RestClient.Builder
@LoadBalanced
RestClient.Builder restClientBuilder() {
return RestClient.builder();
@Autowired
private RestClient.Builder restClientBuilder;
return restClientBuilder.build().get().uri(URI.create("http://stores/stores")).retrieve().body(String.class);
In order to leverage additional capabilities that Spring Boot provides for RestClient.Builder
(for example, observability support) you may want to use the autoconfigured
RestClientBuilderConfigurer
while creating the @LoadBalanced RestClient.Builder
beans:
@LoadBalanced
RestClient.Builder restClientBuilder(RestClientBuilderConfigurer configurer) {
return configurer.configure(RestClient.builder());
To use it, add Spring Cloud LoadBalancer starter to your project. |
Multiple RestClient.Builder
Objects
If you want a RestClient.Builder
that is not load-balanced, create a RestClient.Builder
bean and inject it.
To access the load-balanced RestClient
@LoadBalanced
RestClient.Builder loadBalanced() {
@Primary
@Autowired
@Autowired
@LoadBalanced
private RestClient.Builder loadBalanced;
return loadBalanced.build().get().uri("http://stores/stores")
return restClientBuilder.build().get().uri("http://example.com")
Spring WebClient as a LoadBalancer Client
You can configure WebClient
to automatically use a load-balancer client.
To create a load-balanced WebClient
, create a WebClient.Builder
qualifier, as follows:
@LoadBalanced
public WebClient.Builder loadBalancedWebClientBuilder() {
return WebClient.builder();
@Autowired
private WebClient.Builder webClientBuilder;
public Mono<String> doOtherStuff() {
return webClientBuilder.build().get().uri("http://stores/stores")
.retrieve().bodyToMono(String.class);
The URI needs to use a virtual host name (that is, a service name, not a host name). The Spring Cloud LoadBalancer is used to create a full physical address.
In order to leverage additional capabilities that Spring Boot provides for WebClient.Builder
WebClientCustomizer
beans while creating the @LoadBalanced WebClient.Builder
beans:
@LoadBalanced
public WebClient.Builder loadBalancedWebClientBuilder(ObjectProvider<WebClientCustomizer> customizerProvider) {
WebClient.Builder builder = WebClient.builder();
customizerProvider.orderedStream().forEach((customizer) -> customizer.customize(builder));
return builder;
If you want to use a @LoadBalanced WebClient.Builder , you need to have a Spring Cloud LoadBalancer
implementation in the classpath. We recommend that you add the
Then, ReactiveLoadBalancer is used underneath.
Multiple WebClient.Builder
Objects
If you want a WebClient.Buider
that is not load-balanced, create a WebClient
bean and inject it.
To access the load-balanced WebClient.Builder
@LoadBalanced
WebClient.Builder loadBalanced() {
@Primary
WebClient.Builder webClientBuilder() {
@Autowired
@Autowired
@LoadBalanced
private WebClient.Builder loadBalanced;
public Mono<String> doStuff() {
return webClientBuilder.build().get().uri("http://example.com")
Retrying Failed Requests
A load-balanced RestTemplate
can be configured to retry failed requests.
By default, this logic is disabled.
For the non-reactive version (with RestTemplate
), you can enable it by adding Spring Retry to your application’s classpath. For the reactive version (with WebTestClient
), you need to set spring.cloud.loadbalancer.retry.enabled=true
If you would like to disable the retry logic with Spring Retry or Reactive Retry on the classpath, you can set spring.cloud.loadbalancer.retry.enabled=false
For the non-reactive implementation, if you would like to implement a BackOffPolicy
in your retries, you need to create a bean of type LoadBalancedRetryFactory
and override the createBackOffPolicy()
method.
For the reactive implementation, you just need to enable it by setting spring.cloud.loadbalancer.retry.backoff.enabled
to false
You can set:
spring.cloud.loadbalancer.retry.maxRetriesOnSameServiceInstance
- indicates how many times a request should be retried on the sameServiceInstance
(counted separately for every selected instance) -
spring.cloud.loadbalancer.retry.maxRetriesOnNextServiceInstance
- indicates how many times a request should be retried a newly selectedServiceInstance
spring.cloud.loadbalancer.retry.retryableStatusCodes
- the status codes on which to always retry a failed request.
For the reactive implementation, you can additionally set:
- spring.cloud.loadbalancer.retry.backoff.minBackoff
- Sets the minimum backoff duration (by default, 5 milliseconds)
- spring.cloud.loadbalancer.retry.backoff.maxBackoff
- Sets the maximum backoff duration (by default, max long value of milliseconds)
- spring.cloud.loadbalancer.retry.backoff.jitter
- Sets the jitter used for calculating the actual backoff duration for each call (by default, 0.5).
For the reactive implementation, you can also implement your own LoadBalancerRetryPolicy
to have more detailed control over the load-balanced call retries.
For both implementations, you can also set the exceptions that trigger the replies by adding a list of values under the spring.cloud.loadbalancer.[serviceId].retry.retryable-exceptions
property. If you do, we make sure to add RetryableStatusCodeExceptions
to the list of exceptions provided by you, so that we also retry on retryable status codes. If you do not specify any exceptions via properties, the exceptions we use by default are IOException
, TimeoutException
and RetryableStatusCodeException
. You can also enable retrying on all exceptions by setting spring.cloud.loadbalancer.[serviceId].retry.retry-on-all-exceptions
to true
If you use the blocking implementation with Spring Retries, if you want to keep the behaviour from previous releases, set spring.cloud.loadbalancer.[serviceId].retry.retry-on-all-exceptions to true as that used to be the default mode for the blocking implementation.
Individual Loadbalancer clients may be configured individually with the same properties as above except the prefix is spring.cloud.loadbalancer.clients.<clientId>.* where clientId is the name of the loadbalancer.
For load-balanced retries, by default, we wrap the ServiceInstanceListSupplier bean with RetryAwareServiceInstanceListSupplier to select a different instance from the one previously chosen, if available. You can disable this behavior by setting the value of spring.cloud.loadbalancer.retry.avoidPreviousInstance to false .
LoadBalancedRetryFactory retryFactory() {
return new LoadBalancedRetryFactory() {
public BackOffPolicy createBackOffPolicy(String service) {
return new ExponentialBackOffPolicy();
If you want to add one or more RetryListener
implementations to your retry functionality, you need to
create a bean of type LoadBalancedRetryListenerFactory
and return the RetryListener
array
you would like to use for a given service, as the following example shows:
LoadBalancedRetryListenerFactory retryListenerFactory() {
return new LoadBalancedRetryListenerFactory() {
public RetryListener[] createRetryListeners(String service) {
return new RetryListener[]{new RetryListener() {
public <T, E extends Throwable> boolean open(RetryContext context, RetryCallback<T, E> callback) {
//TODO Do you business...
return true;
public <T, E extends Throwable> void close(RetryContext context, RetryCallback<T, E> callback, Throwable throwable) {
public <T, E extends Throwable> void onError(RetryContext context, RetryCallback<T, E> callback, Throwable throwable) {
Spring WebFlux WebClient
as a Load Balancer Client
The Spring WebFlux can work with both reactive and non-reactive WebClient
configurations, as the topics describe:
with ReactorLoadBalancerExchangeFilterFunction
to use the ReactiveLoadBalancer
If you add Spring Cloud LoadBalancer starter to your project
and if spring-webflux
is on the classpath, ReactorLoadBalancerExchangeFilterFunction
is auto-configured.
The following example shows how to configure a WebClient
to use reactive load-balancer:
@Autowired
private ReactorLoadBalancerExchangeFilterFunction lbFunction;
return WebClient.builder().baseUrl("http://stores")
.filter(lbFunction)
.build()
.get()
.uri("/stores")
.retrieve()
The ReactorLoadBalancer
with a Non-reactive Load Balancer Client
If spring-webflux
is on the classpath, LoadBalancerExchangeFilterFunction
is auto-configured. Note, however, that this
uses a non-reactive client under the hood.
to use load-balancer:
@Autowired
private LoadBalancerExchangeFilterFunction lbFunction;
.filter(lbFunction)
.build()
.get()
.uri("/stores")
.retrieve()
The LoadBalancerClient
WARN: This approach is now deprecated. We suggest that you use WebFlux with reactive Load-Balancer instead.
Ignore Network Interfaces
Sometimes, it is useful to ignore certain named network interfaces so that they can be excluded from Service Discovery registration (for example, when running in a Docker container).
A list of regular expressions can be set to cause the desired network interfaces to be ignored.
The following configuration ignores the docker0
interface and all interfaces that start with veth
spring: cloud: inetutils: ignoredInterfaces: - docker0 - veth.*
You can also force the use of only specified network addresses by using a list of regular expressions, as the following example shows:
spring: cloud: inetutils: preferredNetworks: - 192.168 - 10.0
You can also force the use of only site-local addresses, as the following example shows:
spring: cloud: inetutils: useOnlySiteLocalInterfaces: true
See Inet4Address.html.isSiteLocalAddress() for more details about what constitutes a site-local address.
Enabled Features
Spring Cloud Commons provides a /features
actuator endpoint.
This endpoint returns features available on the classpath and whether they are enabled.
The information returned includes the feature type, name, version, and vendor.
Feature types
There are two types of 'features': abstract and named.
Abstract features are features where an interface or abstract class is defined and that an implementation the creates, such as DiscoveryClient
, LoadBalancerClient
, or LockService
The abstract class or interface is used to find a bean of that type in the context.
The version displayed is bean.getClass().getPackage().getImplementationVersion()
Named features are features that do not have a particular class they implement. These features include “Circuit Breaker”, “API Gateway”, “Spring Cloud Bus”, and others. These features require a name and a bean type.
Declaring features
Any module can declare any number of HasFeature
beans, as the following examples show:
public HasFeatures commonsFeatures() {
return HasFeatures.abstractFeatures(DiscoveryClient.class, LoadBalancerClient.class);
public HasFeatures consulFeatures() {
return HasFeatures.namedFeatures(
new NamedFeature("Spring Cloud Bus", ConsulBusAutoConfiguration.class),
new NamedFeature("Circuit Breaker", HystrixCommandAspect.class));
HasFeatures localFeatures() {
return HasFeatures.builder()
.abstractFeature(Something.class)
.namedFeature(new NamedFeature("Some Other Feature", Someother.class))
.abstractFeature(Somethingelse.class)
Each of these beans should go in an appropriately guarded @Configuration
Spring Cloud Compatibility Verification
Due to the fact that some users have problem with setting up Spring Cloud application, we’ve decided to add a compatibility verification mechanism. It will break if your current setup is not compatible with Spring Cloud requirements, together with a report, showing what exactly went wrong.
At the moment we verify which version of Spring Boot is added to your classpath.
Example of a report
*************************** APPLICATION FAILED TO START *************************** Description: Your project setup is incompatible with our requirements due to following reasons: - Spring Boot [2.1.0.RELEASE] is not compatible with this Spring Cloud release train Action: Consider applying the following actions: - Change Spring Boot version to one of the following versions [1.2.x, 1.3.x] . You can find the latest Spring Boot versions here [https://spring.io/projects/spring-boot#learn]. If you want to learn more about the Spring Cloud Release train compatibility, you can visit this page [https://spring.io/projects/spring-cloud#overview] and check the [Release Trains] section.
In order to disable this feature, set spring.cloud.compatibility-verifier.enabled
to false
If you want to override the compatible Spring Boot versions, just set the
spring.cloud.compatibility-verifier.compatible-boot-versions
property with a comma separated list
of compatible Spring Boot versions.
