This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Cloud Commons 4.2.1! |
Spring Cloud Context: Application Context Services
Spring Boot has an opinionated view of how to build an application with Spring. For instance, it has conventional locations for common configuration files and has endpoints for common management and monitoring tasks. Spring Cloud builds on top of that and adds a few features that many components in a system would use or occasionally need.
The Bootstrap Application Context
A Spring Cloud application operates by creating a “bootstrap” context, which is a parent context for the main application.
This context is responsible for loading configuration properties from the external sources and for decrypting properties in the local external configuration files.
The two contexts share an Environment
, which is the source of external properties for any Spring application.
By default, bootstrap properties (not bootstrap.properties
but properties that are loaded during the bootstrap phase) are added with high precedence, so they cannot be overridden by local configuration.
The bootstrap context uses a different convention for locating external configuration than the main application context.
Instead of application.yml
(or .properties
), you can use bootstrap.yml
, keeping the external configuration for bootstrap and main context nicely separate.
The following listing shows an example:
spring: application: name: foo cloud: config: uri: ${SPRING_CONFIG_URI:http://localhost:8888}
If your application needs any application-specific configuration from the server, it is a good idea to set the spring.application.name
(in bootstrap.yml
or application.yml
For the property spring.application.name
to be used as the application’s context ID, you must set it in bootstrap.[properties | yml]
If you want to retrieve specific profile configuration, you should also set spring.profiles.active
You can disable the bootstrap process completely by setting spring.cloud.bootstrap.enabled=false
(for example, in system properties).
Application Context Hierarchies
If you build an application context from SpringApplication
or SpringApplicationBuilder
, the Bootstrap context is added as a parent to that context.
It is a feature of Spring that child contexts inherit property sources and profiles from their parent, so the “main” application context contains additional property sources, compared to building the same context without Spring Cloud Config.
The additional property sources are:
“bootstrap”: If any
PropertySourceLocators
are found in the bootstrap context and if they have non-empty properties, an optionalCompositePropertySource
appears with high priority. An example would be properties from the Spring Cloud Config Server. See “Customizing the Bootstrap Property Sources” for how to customize the contents of this property source.
Prior to Spring Cloud 2022.0.3 PropertySourceLocators (including the ones for Spring Cloud Config) were run during
the main application context and not in the Bootstrap context. You can force PropertySourceLocators to be run during the
Bootstrap context by setting spring.cloud.config.initialize-on-context-refresh=true in bootstrap.[properties | yaml] .
“applicationConfig: [classpath:bootstrap.yml]” (and related files if Spring profiles are active): If you have a
bootstrap.yml
(or.properties
), those properties are used to configure the bootstrap context. Then they get added to the child context when its parent is set. They have lower precedence than theapplication.yml
(or.properties
) and any other property sources that are added to the child as a normal part of the process of creating a Spring Boot application. See “Changing the Location of Bootstrap Properties” for how to customize the contents of these property sources.
Because of the ordering rules of property sources, the “bootstrap” entries take precedence.
However, note that these do not contain any data from bootstrap.yml
, which has very low precedence but can be used to set defaults.
You can extend the context hierarchy by setting the parent context of any ApplicationContext
you create — for example, by using its own interface or with the SpringApplicationBuilder
convenience methods (parent()
, child()
and sibling()
The bootstrap context is the parent of the most senior ancestor that you create yourself.
Every context in the hierarchy has its own “bootstrap” (possibly empty) property source to avoid promoting values inadvertently from parents down to their descendants.
If there is a config server, every context in the hierarchy can also (in principle) have a different spring.application.name
and, hence, a different remote property source.
Normal Spring application context behavior rules apply to property resolution: properties from a child context override those in
the parent, by name and also by property source name.
(If the child has a property source with the same name as the parent, the value from the parent is not included in the child).
Note that the SpringApplicationBuilder
lets you share an Environment
amongst the whole hierarchy, but that is not the default.
Thus, sibling contexts (in particular) do not need to have the same profiles or property sources, even though they may share common values with their parent.
The bootstrap.yml
(or .properties
) location can be specified by setting spring.cloud.bootstrap.name
(default: bootstrap
), spring.cloud.bootstrap.location
(default: empty) or spring.cloud.bootstrap.additional-location
(default: empty) — for example, in System properties.
Those properties behave like the spring.config.*
variants with the same name.
With spring.cloud.bootstrap.location
the default locations are replaced and only the specified ones are used.
To add locations to the list of default ones, spring.cloud.bootstrap.additional-location
can be used.
In fact, they are used to set up the bootstrap ApplicationContext
by setting those properties in its Environment
If there is an active profile (from spring.profiles.active
or through the Environment
API in the context you are building), properties in that profile get loaded as well, the same as in a regular Spring Boot app — for example, from bootstrap-development.properties
for a development
profile.
Overriding the Values of Remote Properties
The property sources that are added to your application by the bootstrap context are often “remote” (from example, from Spring Cloud Config Server).
By default, they cannot be overridden locally.
If you want to let your applications override the remote properties with their own system properties or config files, the remote property source has to grant it permission by setting spring.cloud.config.allowOverride=true
(it does not work to set this locally).
Once that flag is set, two finer-grained settings control the location of the remote properties in relation to system properties and the application’s local configuration:
spring.cloud.config.overrideNone=true
: Override from any local property source. -
spring.cloud.config.overrideSystemProperties=false
: Only system properties, command line arguments, and environment variables (but not the local config files) should override the remote settings.
Customizing the Bootstrap Configuration
The bootstrap context can be set to do anything you like by adding entries to /META-INF/spring.factories
under a key named org.springframework.cloud.bootstrap.BootstrapConfiguration
This holds a comma-separated list of Spring @Configuration
classes that are used to create the context.
Any beans that you want to be available to the main application context for autowiring can be created here.
There is a special contract for @Beans
of type ApplicationContextInitializer
If you want to control the startup sequence, you can mark classes with the @Order
annotation (the default order is last
When adding custom BootstrapConfiguration , be careful that the classes you add are not @ComponentScanned by mistake into your “main” application context, where they might not be needed.
Use a separate package name for boot configuration classes and make sure that name is not already covered by your @ComponentScan or @SpringBootApplication annotated configuration classes.
The bootstrap process ends by injecting initializers into the main SpringApplication
instance (which is the normal Spring Boot startup sequence, whether it runs as a standalone application or is deployed in an application server).
First, a bootstrap context is created from the classes found in spring.factories
Then, all @Beans
are added to the main SpringApplication
before it is started.
The default property source for external configuration added by the bootstrap process is the Spring Cloud Config Server, but you can add additional sources by adding beans of type PropertySourceLocator
to the bootstrap context (through spring.factories
For instance, you can insert additional properties from a different server or from a database.
As an example, consider the following custom locator:
public class CustomPropertySourceLocator implements PropertySourceLocator {
public PropertySource<?> locate(Environment environment) {
return new MapPropertySource("customProperty",
Collections.<String, Object>singletonMap("property.from.sample.custom.source", "worked as intended"));
The Environment
that is passed in is the one for the ApplicationContext
about to be created — in other words, the one for which we supply additional property sources.
It already has its normal Spring Boot-provided property sources, so you can use those to locate a property source specific to this Environment
(for example, by keying it on spring.application.name
, as is done in the default Spring Cloud Config Server property source locator).
If you create a jar with this class in it and then add a META-INF/spring.factories
containing the following setting, the customProperty
PropertySource
appears in any application that includes that jar on its classpath:
org.springframework.cloud.bootstrap.BootstrapConfiguration=sample.custom.CustomPropertySourceLocator
As of Spring Cloud 2022.0.3, Spring Cloud will now call PropertySourceLocators
twice. The first fetch
will retrieve any property sources without any profiles. These property sources will have the opportunity to
activate profiles using spring.profiles.active
. After the main application context starts PropertySourceLocators
will be called a second time, this time with any active profiles allowing PropertySourceLocators
to locate
any additional PropertySources
with profiles.
Logging Configuration
If you use Spring Boot to configure log settings, you should place this configuration in bootstrap.[yml | properties]
if you would like it to apply to all events.
For Spring Cloud to initialize logging configuration properly, you cannot use a custom prefix.
For example, using custom.loggin.logpath is not recognized by Spring Cloud when initializing the logging system.
Environment Changes
The application listens for an EnvironmentChangeEvent
and reacts to the change in a couple of standard ways (additional ApplicationListeners
can be added as @Beans
in the normal way).
When an EnvironmentChangeEvent
is observed, it has a list of key values that have changed, and the application uses those to:
Re-bind any
@ConfigurationProperties
beans in the context. -
Set the logger levels for any properties in
logging.level.*
Note that the Spring Cloud Config Client does not, by default, poll for changes in the Environment
Generally, we would not recommend that approach for detecting changes (although you can set it up with a
@Scheduled
annotation).
If you have a scaled-out client application, it is better to broadcast the EnvironmentChangeEvent
to all the instances instead of having them polling for changes (for example, by using the Spring Cloud Bus).
The EnvironmentChangeEvent
covers a large class of refresh use cases, as long as you can actually make a change to the Environment
and publish the event.
Note that those APIs are public and part of core Spring).
You can verify that the changes are bound to @ConfigurationProperties
beans by visiting the /configprops
endpoint (a standard Spring Boot Actuator feature).
For instance, a DataSource
can have its maxPoolSize
changed at runtime (the default DataSource
created by Spring Boot is a @ConfigurationProperties
bean) and grow capacity dynamically.
Re-binding @ConfigurationProperties
does not cover another large class of use cases, where you need more control over the refresh and where you need a change to be atomic over the whole ApplicationContext
To address those concerns, we have @RefreshScope
Java Records annotated with @ConfigurationProperties cannot be refreshed.
Refresh Scope
When there is a configuration change, a Spring @Bean
that is marked as @RefreshScope
gets special treatment.
This feature addresses the problem of stateful beans that get their configuration injected only when they are initialized.
For instance, if a DataSource
has open connections when the database URL is changed through the Environment
, you probably want the holders of those connections to be able to complete what they are doing.
Then, the next time something borrows a connection from the pool, it gets one with the new URL.
Sometimes, it might even be mandatory to apply the @RefreshScope
annotation on some beans that can be only initialized once.
If a bean is “immutable”, you have to either annotate the bean with @RefreshScope
or specify the classname under the property key: spring.cloud.refresh.extra-refreshable
If you hava a DataSource bean that is a HikariDataSource , it can not be
refreshed. It is the default value for spring.cloud.refresh.never-refreshable . Choose a
different DataSource implementation if you need it to be refreshed.
Refresh scope beans are lazy proxies that initialize when they are used (that is, when a method is called), and the scope acts as a cache of initialized values. To force a bean to re-initialize on the next method call, you must invalidate its cache entry.
The RefreshScope
is a bean in the context and has a public refreshAll()
method to refresh all beans in the scope by clearing the target cache.
The /refresh
endpoint exposes this functionality (over HTTP or JMX).
To refresh an individual bean by name, there is also a refresh(String)
method.
To expose the /refresh
endpoint, you need to add following configuration to your application:
management:
endpoints:
web:
exposure:
include: refresh
@RefreshScope works (technically) on a @Configuration class, but it might lead to surprising behavior.
For example, it does not mean that all the @Beans defined in that class are themselves in @RefreshScope .
Specifically, anything that depends on those beans cannot rely on them being updated when a refresh is initiated, unless it is itself in @RefreshScope .
In that case, it is rebuilt on a refresh and its dependencies are re-injected.
At that point, they are re-initialized from the refreshed @Configuration ).
Removing a configuration value and then performing a refresh will not update the presence of the configuration value. The configuration property must be present in order to update the value after a refresh. If you are relying on the presence of a value in your application you might want to switch your logic to rely on its absence instead. Another option would be to rely on the value changing rather than not being present in the application’s configuration. |
Context Refresh is not supported for Spring AOT transformations and native images. For AOT and native images, spring.cloud.refresh.enabled needs to be set to false .
Refresh Scope on Restart
Seamlessly refreshing beans on restart is especially useful for applications that run with JVM Checkpoint Restore (such as Project CRaC). To allow this ability, we now instantiate a RefreshScopeLifecycle
bean that triggers Context Refresh on restart, resulting in rebinding configuration properties and refreshing any beans annotated with @RefreshScope
. You can disable this behavior by setting spring.cloud.refresh.on-restart.enabled
to false
Encryption and Decryption
Spring Cloud has an Environment
pre-processor for decrypting property values locally.
It follows the same rules as the Spring Cloud Config Server and has the same external configuration through encrypt.*
Thus, you can use encrypted values in the form of {cipher}*
, and, as long as there is a valid key, they are decrypted before the main application context gets the Environment
settings.
To use the encryption features in an application, you need to include Spring Security RSA in your classpath (Maven co-ordinates: org.springframework.security:spring-security-rsa
), and you also need the full strength JCE extensions in your JVM.
If you get an exception due to "Illegal key size" and you use Sun’s JDK, you need to install the Java Cryptography Extension (JCE) Unlimited Strength Jurisdiction Policy Files. See the following links for more information:
Extract the files into the JDK/jre/lib/security folder for whichever version of JRE/JDK x64/x86 you use.
Endpoints
For a Spring Boot Actuator application, some additional management endpoints are available. You can use:
POST
to/actuator/env
to update theEnvironment
and rebind@ConfigurationProperties
and log levels. To enabled this endpoint you must setmanagement.endpoint.env.post.enabled=true
/actuator/refresh
to re-load the boot strap context and refresh the@RefreshScope
beans. -
/actuator/restart
to close theApplicationContext
and restart it (disabled by default). -
/actuator/pause
and/actuator/resume
for calling theLifecycle
methods (stop()
andstart()
on theApplicationContext
While enabling the POST method for /actuator/env endpoint can provide flexibility and convenience in managing your application environment variables,
it’s critical to ensure that the endpoint is secured and monitored to prevent potential security risks.
Add a spring-boot-starter-security dependency to configure access control for the actuator’s endpoint.
If you disable the /actuator/restart endpoint then the /actuator/pause and /actuator/resume endpoints
will also be disabled since they are just a special case of /actuator/restart .
