This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Cloud Commons 4.2.0! |
Security
Single Sign On
All of the OAuth2 SSO and resource server features moved to Spring Boot in version 1.3. You can find documentation in the Spring Boot user guide. |
Client Token Relay
If your app is a user facing OAuth2 client (i.e. has declared
@EnableOAuth2Sso
or @EnableOAuth2Client
) then it has an
OAuth2ClientContext
in request scope from Spring Boot. You can
create your own OAuth2RestTemplate
from this context and an
autowired OAuth2ProtectedResourceDetails
, and then the context will
always forward the access token downstream, also refreshing the access
token automatically if it expires. (These are features of Spring
Security and Spring Boot.)
Resource Server Token Relay
If your app has @EnableResourceServer
you might want to relay the
incoming token downstream to other services. If you use a
RestTemplate
to contact the downstream services then this is just a
matter of how to create the template with the right context.
If your service uses UserInfoTokenServices
to authenticate incoming
tokens (i.e. it is using the security.oauth2.user-info-uri
configuration), then you can simply create an OAuth2RestTemplate
using an autowired OAuth2ClientContext
(it will be populated by the
authentication process before it hits the backend code). Equivalently
(with Spring Boot 1.4), you can inject a
UserInfoRestTemplateFactory
and grab its OAuth2RestTemplate
in
your configuration. For example:
public OAuth2RestTemplate restTemplate(UserInfoRestTemplateFactory factory) {
return factory.getUserInfoRestTemplate();
This rest template will then have the same OAuth2ClientContext
(request-scoped) that is used by the authentication filter, so you can
use it to send requests with the same access token.
If your app is not using UserInfoTokenServices
but is still a client
(i.e. it declares @EnableOAuth2Client
or @EnableOAuth2Sso
), then
with Spring Security Cloud any OAuth2RestOperations
that the user
creates from an @Autowired
OAuth2Context
will also forward
tokens. This feature is implemented by default as an MVC handler
interceptor, so it only works in Spring MVC. If you are not using MVC
you can use a custom filter or AOP interceptor wrapping an
AccessTokenContextRelay
to provide the same feature.
Here’s a basic example showing the use of an autowired rest template created elsewhere ("foo.com" is a Resource Server accepting the same tokens as the surrounding app):
@Autowired
private OAuth2RestOperations restTemplate;
@RequestMapping("/relay")
public String relay() {
ResponseEntity<String> response =
restTemplate.getForEntity("https://foo.com/bar", String.class);
return "Success! (" + response.getBody() + ")";
If you don’t want to forward tokens (and that is a valid
choice, since you might want to act as yourself, rather than the
client that sent you the token), then you only need to create your own
OAuth2Context
instead of autowiring the default one.
Feign clients will also pick up an interceptor that uses the
OAuth2ClientContext
if it is available, so they should also do a
token relay anywhere where a RestTemplate
would.
