This version is still in development and is not considered stable yet. For the latest stable version, please use Spring-Cloud-CircuitBreaker 3.1.3! |
Bulkhead pattern supporting
If resilience4j-bulkhead
is on the classpath, Spring Cloud CircuitBreaker will wrap all methods with a Resilience4j Bulkhead.
You can disable the Resilience4j Bulkhead by setting spring.cloud.circuitbreaker.bulkhead.resilience4j.enabled
to false
Spring Cloud CircuitBreaker Resilience4j provides two implementation of bulkhead pattern:
a
SemaphoreBulkhead
which uses Semaphores -
a
FixedThreadPoolBulkhead
which uses a bounded queue and a fixed thread pool.
By default, Spring Cloud CircuitBreaker Resilience4j uses FixedThreadPoolBulkhead
. To modify the default behavior to use SemaphoreBulkhead
set the property spring.cloud.circuitbreaker.resilience4j.enableSemaphoreDefaultBulkhead
to true
For more information on implementation of Bulkhead patterns see the Resilience4j Bulkhead.
The Customizer<Resilience4jBulkheadProvider>
can be used to provide a default Bulkhead
and ThreadPoolBulkhead
configuration.
public Customizer<Resilience4jBulkheadProvider> defaultBulkheadCustomizer() {
return provider -> provider.configureDefault(id -> new Resilience4jBulkheadConfigurationBuilder()
.bulkheadConfig(BulkheadConfig.custom().maxConcurrentCalls(4).build())
.threadPoolBulkheadConfig(ThreadPoolBulkheadConfig.custom().coreThreadPoolSize(1).maxThreadPoolSize(1).build())
.build()
