此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring-Cloud-CircuitBreaker 3.1.3spring-doc.cadn.net.cn
断路器属性配置
您可以配置CircuitBreakerTimeLimiterconfigs 或实例。 Property configuration 的优先级高于 JavaCustomizer配置。spring-doc.cadn.net.cn
优先级从上到下降序。spring-doc.cadn.net.cn
ReactiveResilience4JCircuitBreakerFactory.create(String id, String groupName)
全局默认属性配置
resilience4j.circuitbreaker:
    configs:
        default:
            registerHealthIndicator: true
            slidingWindowSize: 50
resilience4j.timelimiter:
    configs:
        default:
            timeoutDuration: 5s
            cancelRunningFuture: true
Configs 属性配置
    configs:
        groupA:
            slidingWindowSize: 200
    configs:
        groupC:
            timeoutDuration: 3s
实例属性配置
 instances:
     backendA:
         slidingWindowSize: 100
     backendB:
         permittedNumberOfCallsInHalfOpenState: 3
         slidingWindowType: TIME_BASED
         recordFailurePredicate: io.github.robwin.exception.RecordFailurePredicate
 instances:
     backendA:
         timeoutDuration: 2s
     backendB:
         timeoutDuration: 1s
         cancelRunningFuture: false
  • ReactiveResilience4JCircuitBreakerFactory.create("backendA")Resilience4JCircuitBreakerFactory.create("backendA")将适用instances backendA propertiesspring-doc.cadn.net.cn
  • ReactiveResilience4JCircuitBreakerFactory.create("backendA", "groupA")Resilience4JCircuitBreakerFactory.create("backendA", "groupA")将适用instances backendA propertiesspring-doc.cadn.net.cn
  • ReactiveResilience4JCircuitBreakerFactory.create("backendC")Resilience4JCircuitBreakerFactory.create("backendC")将适用global default propertiesspring-doc.cadn.net.cn
  • ReactiveResilience4JCircuitBreakerFactory.create("backendC", "groupC")Resilience4JCircuitBreakerFactory.create("backendC", "groupC")将适用global default CircuitBreaker properties and config groupC TimeLimiter propertiesspring-doc.cadn.net.cn
有关 Resilience4j 属性配置的更多信息,请参阅 Resilience4J Spring Boot 2 配置spring-doc.cadn.net.cn
禁用 TimeLimiter
默认情况下,TimeLimiter已启用,并且每次执行都有时间限制。此时间限制是显式定义的,也可以是默认时间限制(由io.github.resilience4j.timelimiter.TimeLimiterConfig#ofDefaults) 被使用。spring-doc.cadn.net.cn
TimeLimiter可以通过设置属性spring.cloud.circuitbreaker.resilience4j.disable-time-limitertrue.spring-doc.cadn.net.cn
spring:
	cloud:
		circuitbreaker:
			resilience4j:
				disable-time-limiter: true
TimeLimiter也可以使用spring.cloud.circuitbreaker.resilience4j.disable-time-limiter-map如下:spring-doc.cadn.net.cn
spring:
	cloud:
		circuitbreaker:
			resilience4j:
				disable-time-limiter-map:
					group1: true
					instanceA: false
					instanceB: true
这些用于禁用的选项TimeLimitspring-cloud-circuitbreaker,适用于基本和反应式断路器实现。spring-doc.cadn.net.cn
禁用的优先顺序为:instance > group > global.基于上述配置,instanceBgroup1TimeLimiterdisabled 但instanceA已启用。对于所有其他实例和组,它将回退到全局设置的值spring.cloud.circuitbreaker.resilience4j.disable-time-limiter如果spring.cloud.circuitbreaker.resilience4j.disable-time-limiter未设置,则默认情况下,TimeLimit为其余断路器实例和组启用。spring-doc.cadn.net.cn
