This version is still in development and is not considered stable yet. For the latest stable version, please use Spring-Cloud-CircuitBreaker 3.1.3!spring-doc.cn
Configuring Spring Retry Circuit Breakers
Spring Retry provides declarative retry support for Spring applications. A subset of the project includes the ability to implement circuit breaker functionality. Spring Retry provides a circuit breaker implementation via a combination of it’s CircuitBreakerRetryPolicy and a stateful retry. All circuit breakers created using Spring Retry will be created using the CircuitBreakerRetryPolicy and a DefaultRetryState. Both of these classes can be configured using SpringRetryConfigBuilder.spring-doc.cn
Default Configuration
To provide a default configuration for all of your circuit breakers create a Customizer bean that is passed a SpringRetryCircuitBreakerFactory. The configureDefault method can be used to provide a default configuration.spring-doc.cn
public Customizer<SpringRetryCircuitBreakerFactory> defaultCustomizer() {
	return factory -> factory.configureDefault(id -> new SpringRetryConfigBuilder(id)
    	.retryPolicy(new TimeoutRetryPolicy()).build());
Specific Circuit Breaker Configuration
Similarly to providing a default configuration, you can create a Customizer bean this is passed a SpringRetryCircuitBreakerFactory.spring-doc.cn
public Customizer<SpringRetryCircuitBreakerFactory> slowCustomizer() {
	return factory -> factory.configure(builder -> builder.retryPolicy(new SimpleRetryPolicy(1)).build(), "slow");
In addition to configuring the circuit breaker that is created you can also customize the circuit breaker after it has been created but before it is returned to the caller. To do this you can use the addRetryTemplateCustomizers method. This can be useful for adding event handlers to the RetryTemplate.spring-doc.cn
	return factory -> factory.addRetryTemplateCustomizers(retryTemplate -> retryTemplate.registerListener(new RetryListener() {
		public <T, E extends Throwable> boolean open(RetryContext context, RetryCallback<T, E> callback) {
			return false;
		public <T, E extends Throwable> void close(RetryContext context, RetryCallback<T, E> callback, Throwable throwable) {
		public <T, E extends Throwable> void onError(RetryContext context, RetryCallback<T, E> callback, Throwable throwable) {
