This version is still in development and is not considered stable yet. For the latest stable version, please use Spring-Cloud-CircuitBreaker 3.1.3!spring-doc.cn
Bulkhead Properties Configuration
You can configure ThreadPoolBulkhead and SemaphoreBulkhead instances in your application’s configuration properties file. Property configuration has higher priority than Java Customizer configuration.spring-doc.cn
resilience4j.thread-pool-bulkhead:
    instances:
        backendA:
            maxThreadPoolSize: 1
            coreThreadPoolSize: 1
resilience4j.bulkhead:
    instances:
        backendB:
            maxConcurrentCalls: 10
For more inforamtion on the Resilience4j property configuration, see Resilience4J Spring Boot 2 Configuration.spring-doc.cn
