This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.0!spring-doc.cn
@RabbitListener @Payload Validation
Starting with version 2.3.7, it is now easier to add a Validator to validate @RabbitListener and @RabbitHandler @Payload arguments. Now, you can simply add the validator to the registrar itself.spring-doc.cn
@EnableRabbit
public class Config implements RabbitListenerConfigurer {
    public void configureRabbitListeners(RabbitListenerEndpointRegistrar registrar) {
      registrar.setValidator(new MyValidator());
When using Spring Boot with the validation starter, a LocalValidatorFactoryBean is auto-configured:
@EnableRabbit
    @Autowired
    private LocalValidatorFactoryBean validator;
      registrar.setValidator(this.validator);
To validate:spring-doc.cn
public static class ValidatedClass {
  @Max(10)
  private int bar;
  public int getBar() {
    return this.bar;
  public void setBar(int bar) {
    this.bar = bar;
@RabbitListener(id="validated", queues = "queue1", errorHandler = "validationErrorHandler",
      containerFactory = "jsonListenerContainerFactory")
public void validatedListener(@Payload @Valid ValidatedClass val) {
public RabbitListenerErrorHandler validationErrorHandler() {
    return (m, e) -> {
