This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.0!spring-doc.cn
Changes to 1.2 Since 1.1
RabbitMQ Version
Spring AMQP now uses RabbitMQ 3.1.x by default (but retains compatibility with earlier versions). Certain deprecations have been added for features no longer supported by RabbitMQ 3.1.x — federated exchanges and the immediate property on the RabbitTemplate.spring-doc.cn
Rabbit Admin
RabbitAdmin now provides an option to let exchange, queue, and binding declarations continue when a declaration fails. Previously, all declarations stopped on a failure. By setting ignore-declaration-exceptions, such exceptions are logged (at the WARN level), but further declarations continue. An example where this might be useful is when a queue declaration fails because of a slightly different ttl setting that would normally stop other declarations from proceeding.spring-doc.cn
RabbitAdmin now provides an additional method called getQueueProperties(). You can use this determine if a queue exists on the broker (returns null for a non-existent queue). In addition, it returns the current number of messages in the queue as well as the current number of consumers.spring-doc.cn
Rabbit Template
Previously, when the …​sendAndReceive() methods were used with a fixed reply queue, two custom headers were used for correlation data and to retain and restore reply queue information. With this release, the standard message property (correlationId) is used by default, although you can specify a custom property to use instead. In addition, nested replyTo information is now retained internally in the template, instead of using a custom header.spring-doc.cn
The immediate property is deprecated. You must not set this property when using RabbitMQ 3.0.x or greater.spring-doc.cn
JSON Message Converters
A Jackson 2.x MessageConverter is now provided, along with the existing converter that uses Jackson 1.x.spring-doc.cn
Automatic Declaration of Queues and Other Items
Previously, when declaring queues, exchanges and bindings, you could not define which connection factory was used for the declarations. Each RabbitAdmin declared all components by using its connection.spring-doc.cn
Starting with this release, you can now limit declarations to specific RabbitAdmin instances. See Conditional Declaration.spring-doc.cn
AMQP Remoting
Facilities are now provided for using Spring remoting techniques, using AMQP as the transport for the RPC calls. For more information see Spring Remoting with AMQP.spring-doc.cn
Requested Heart Beats
Several users have asked for the underlying client connection factory’s requestedHeartBeats property to be exposed on the Spring AMQP CachingConnectionFactory. This is now available. Previously, it was necessary to configure the AMQP client factory as a separate bean and provide a reference to it in the CachingConnectionFactory.spring-doc.cn
