This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.0!spring-doc.cn
Micrometer Observation
Using Micrometer for observation is now supported, since version 3.0, for the RabbitTemplate and listener containers.spring-doc.cn
Set observationEnabled on each component to enable observation; this will disable Micrometer Timers because the timers will now be managed with each observation. When using annotated listeners, set observationEnabled on the container factory.spring-doc.cn
Refer to Micrometer Tracing for more information.spring-doc.cn
To add tags to timers/traces, configure a custom RabbitTemplateObservationConvention or RabbitListenerObservationConvention to the template or listener container, respectively.spring-doc.cn
The default implementations add the name tag for template observations and listener.id tag for containers.spring-doc.cn
You can either subclass DefaultRabbitTemplateObservationConvention or DefaultRabbitListenerObservationConvention or provide completely new implementations.spring-doc.cn
Due to ambiguity in how traces should be handled in a batch, observations are NOT created for Batch Listener Containers.
