This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.0! |
Listening to Multiple Queues
When you use the queues
attribute, you can specify that the associated container can listen to multiple queues.
You can use a @Header
annotation to make the queue name from which a message was received available to the POJO
method.
The following example shows how to do so:
@Component
public class MyService {
@RabbitListener(queues = { "queue1", "queue2" } )
public void processOrder(String data, @Header(AmqpHeaders.CONSUMER_QUEUE) String queue) {
Starting with version 1.5, you can externalize the queue names by using property placeholders and SpEL. The following example shows how to do so:
@Component
@RabbitListener(queues = "#{'${property.with.comma.delimited.queue.names}'.split(',')}" )
Prior to version 1.5, only a single queue could be specified this way. Each queue needed a separate property.
