This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.0!spring-doc.cn
Enable Listener Endpoint Annotations
To enable support for @RabbitListener annotations, you can add @EnableRabbit to one of your @Configuration classes. The following example shows how to do so:spring-doc.cn
@EnableRabbit
public class AppConfig {
    public SimpleRabbitListenerContainerFactory rabbitListenerContainerFactory() {
        SimpleRabbitListenerContainerFactory factory = new SimpleRabbitListenerContainerFactory();
        factory.setConnectionFactory(connectionFactory());
        factory.setConcurrentConsumers(3);
        factory.setMaxConcurrentConsumers(10);
        factory.setContainerCustomizer(container -> /* customize the container */);
        return factory;
Since version 2.0, a DirectMessageListenerContainerFactory is also available. It creates DirectMessageListenerContainer instances.spring-doc.cn
For information to help you choose between SimpleRabbitListenerContainerFactory and DirectRabbitListenerContainerFactory, see Choosing a Container.
Starting with version 2.2.2, you can provide a ContainerCustomizer implementation (as shown above). This can be used to further configure the container after it has been created and configured; you can use this, for example, to set properties that are not exposed by the container factory.spring-doc.cn
Version 2.4.8 provides the CompositeContainerCustomizer for situations where you wish to apply multiple customizers.spring-doc.cn
By default, the infrastructure looks for a bean named rabbitListenerContainerFactory as the source for the factory to use to create message listener containers. In this case, and ignoring the RabbitMQ infrastructure setup, the processOrder method can be invoked with a core poll size of three threads and a maximum pool size of ten threads.spring-doc.cn
You can customize the listener container factory to use for each annotation, or you can configure an explicit default by implementing the RabbitListenerConfigurer interface. The default is required only if at least one endpoint is registered without a specific container factory. See the Javadoc for full details and examples.spring-doc.cn
The container factories provide methods for adding MessagePostProcessor instances that are applied after receiving messages (before invoking the listener) and before sending replies.spring-doc.cn
See Reply Management for information about replies.spring-doc.cn
Starting with version 2.0.6, you can add a RetryTemplate and RecoveryCallback to the listener container factory. It is used when sending replies. The RecoveryCallback is invoked when retries are exhausted. You can use a SendRetryContextAccessor to get information from the context. The following example shows how to do so:spring-doc.cn
factory.setRetryTemplate(retryTemplate);
factory.setReplyRecoveryCallback(ctx -> {
    Message failed = SendRetryContextAccessor.getMessage(ctx);
    Address replyTo = SendRetryContextAccessor.getAddress(ctx);
    Throwable t = ctx.getLastThrowable();
    return null;
If you prefer XML configuration, you can use the <rabbit:annotation-driven> element. Any beans annotated with @RabbitListener are detected.spring-doc.cn
For SimpleRabbitListenerContainer instances, you can use XML similar to the following:spring-doc.cn
<rabbit:annotation-driven/>
<bean id="rabbitListenerContainerFactory"
      class="org.springframework.amqp.rabbit.config.SimpleRabbitListenerContainerFactory">
    <property name="connectionFactory" ref="connectionFactory"/>
    <property name="concurrentConsumers" value="3"/>
    <property name="maxConcurrentConsumers" value="10"/>
</bean>
For DirectMessageListenerContainer instances, you can use XML similar to the following:spring-doc.cn
      class="org.springframework.amqp.rabbit.config.DirectRabbitListenerContainerFactory">
    <property name="consumersPerQueue" value="3"/>
</bean>
Starting with version 2.0, the @RabbitListener annotation has a concurrency property. It supports SpEL expressions (#{…​}) and property placeholders (${…​}). Its meaning and allowed values depend on the container type, as follows:spring-doc.cn
  • For the DirectMessageListenerContainer, the value must be a single integer value, which sets the consumersPerQueue property on the container.spring-doc.cn
  • For the SimpleRabbitListenerContainer, the value can be a single integer value, which sets the concurrentConsumers property on the container, or it can have the form, m-n, where m is the concurrentConsumers property and n is the maxConcurrentConsumers property.spring-doc.cn
In either case, this setting overrides the settings on the factory. Previously you had to define different container factories if you had listeners that required different concurrency.spring-doc.cn
The annotation also allows overriding the factory autoStartup and taskExecutor properties via the autoStartup and executor (since 2.2) annotation properties. Using a different executor for each might help with identifying threads associated with each listener in logs and thread dumps.spring-doc.cn
Version 2.2 also added the ackMode property, which allows you to override the container factory’s acknowledgeMode property.spring-doc.cn
@RabbitListener(id = "manual.acks.1", queues = "manual.acks.1", ackMode = "MANUAL")
public void manual1(String in, Channel channel,
    @Header(AmqpHeaders.DELIVERY_TAG) long tag) throws IOException {
    channel.basicAck(tag, false);
