This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.0! |
Annotated Endpoint Method Signature
So far, we have been injecting a simple String
in our endpoint, but it can actually have a very flexible method signature.
The following example rewrites it to inject the Order
with a custom header:
@Component
public class MyService {
@RabbitListener(queues = "myQueue")
public void processOrder(Order order, @Header("order_type") String orderType) {
The following list shows the arguments that are available to be matched with parameters in listener endpoints:
The raw
org.springframework.amqp.core.Message
The
MessageProperties
from the rawMessage
The
com.rabbitmq.client.Channel
on which the message was received. -
The
org.springframework.messaging.Message
converted from the incoming AMQP message. -
@Header
-annotated method arguments to extract a specific header value, including standard AMQP headers. -
@Headers
-annotated argument that must also be assignable tojava.util.Map
for getting access to all headers. -
The converted payload
A non-annotated element that is not one of the supported types (that is,
Message
, MessageProperties
, Message<?>
and Channel
) is matched with the payload.
You can make that explicit by annotating the parameter with @Payload
You can also turn on validation by adding an extra @Valid
The ability to inject Spring’s message abstraction is particularly useful to benefit from all the information stored in the transport-specific message without relying on the transport-specific API. The following example shows how to do so:
public void processOrder(Message<Order> order) { ...
Handling of method arguments is provided by DefaultMessageHandlerMethodFactory
, which you can further customize to support additional method arguments.
The conversion and validation support can be customized there as well.
For instance, if we want to make sure our Order
is valid before processing it, we can annotate the payload with @Valid
and configure the necessary validator, as follows:
@EnableRabbit
public class AppConfig implements RabbitListenerConfigurer {
public void configureRabbitListeners(RabbitListenerEndpointRegistrar registrar) {
registrar.setMessageHandlerMethodFactory(myHandlerMethodFactory());
public DefaultMessageHandlerMethodFactory myHandlerMethodFactory() {
DefaultMessageHandlerMethodFactory factory = new DefaultMessageHandlerMethodFactory();
factory.setValidator(myValidator());
return factory;
