This version is still in development and is not considered stable yet. For the latest stable version, please use Spring AMQP 3.2.0!spring-doc.cn
Adding a Custom HandlerMethodArgumentResolver to @RabbitListener
Starting with version 2.3.7 you are able to add your own HandlerMethodArgumentResolver and resolve custom method parameters. All you need is to implement RabbitListenerConfigurer and use method setCustomMethodArgumentResolvers() from class RabbitListenerEndpointRegistrar.spring-doc.cn
class CustomRabbitConfig implements RabbitListenerConfigurer {
    public void configureRabbitListeners(RabbitListenerEndpointRegistrar registrar) {
        registrar.setCustomMethodArgumentResolvers(
				new HandlerMethodArgumentResolver() {
					public boolean supportsParameter(MethodParameter parameter) {
						return CustomMethodArgument.class.isAssignableFrom(parameter.getParameterType());
					public Object resolveArgument(MethodParameter parameter, org.springframework.messaging.Message<?> message) {
						return new CustomMethodArgument(
								(String) message.getPayload(),
								message.getHeaders().get("customHeader", String.class)
