This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Vault 3.2.0! |
Vault Repositories
Working with VaultTemplate
and responses mapped to Java classes allows basic data operations like read, write and delete.
Vault repositories apply Spring Data’s repository concept on top of Vault.
A Vault repository exposes basic CRUD functionality and supports query derivation with predicates constraining the identifier property, paging and sorting.
Vault repositories use the key/value secrets engine functionality to persist and query data.
As of version 2.4, Spring Vault can use additionally key/value version 2 secrets engine, the actual secrets engine version is discovered during runtime.
Deletes within versioned key/value secrets engine use the DELETE operation. Secrets are not destroyed through CrudRepository.delete(…) .
Vault Repositories determine the mount path through Vault’s sys/internal/ui/mounts/… endpoint. Make sure that your policy allows accessing that path, otherwise you won’t be able to use the repository abstraction.
Read more about Spring Data Repositories in the Spring Data Commons reference documentation. The reference documentation will give you an introduction to Spring Data repositories. |
Usage
To access domain entities stored in Vault you can leverage repository support that eases implementing those quite significantly.
@Secret
class Credentials {
@Id String id;
String password;
String socialSecurityNumber;
Address address;
We have a pretty simple domain object here.
Note that it has a property named id
annotated with
org.springframework.data.annotation.Id
and a @Secret
annotation on its type.
Those two are responsible for creating the actual key used to persist the object as JSON inside Vault.
Properties annotated with @Id as well as those named id are considered as the identifier properties.
Those with the annotation are favored over others.
The next step is to declare a repository interface that uses the domain object.
Credentials
entitiesinterface CredentialsRepository extends CrudRepository<Credentials, String> {
As our repository extends CrudRepository
it provides basic CRUD and query methods.
Vault repositories require Spring Data components.
Make sure to include spring-data-commons
and spring-data-keyvalue
artifacts in your class path.
The easiest way to achieve this, is by setting up dependency management and adding the artifacts to your pom.xml
Then add the following to pom.xml
dependencies section.
<dependencyManagement>
<dependencies>
<dependency>
<groupId>org.springframework.data</groupId>
<artifactId>spring-data-bom</artifactId>
<version>2025.0.0</version>
<scope>import</scope>
<type>pom</type>
</dependency>
</dependencies>
</dependencyManagement>
<dependencies>
<!-- other dependency elements omitted -->
<dependency>
<groupId>org.springframework.vault</groupId>
<artifactId>spring-vault-core</artifactId>
<version>3.2.1-SNAPSHOT</version>
</dependency>
<dependency>
<artifactId>spring-data-keyvalue</artifactId>
<!-- Version inherited from the BOM -->
</dependency>
</dependencies>
The thing we need in between to glue things together is the according Spring configuration.
@EnableVaultRepositories
class ApplicationConfig {
VaultTemplate vaultTemplate() {
return new VaultTemplate(…);
Given the setup above we can go on and inject CredentialsRepository
into our components.
@Autowired CredentialsRepository repo;
void basicCrudOperations() {
Credentials creds = new Credentials("heisenberg", "327215", "AAA-GG-SSSS");
rand.setAddress(new Address("308 Negra Arroyo Lane", "Albuquerque", "New Mexico", "87104"));
repo.save(creds); (1)
repo.findOne(creds.getId()); (2)
repo.count(); (3)
repo.delete(creds); (4)
1 | Stores properties of Credentials inside Vault Hash with a key pattern keyspace/id , in this case credentials/heisenberg , in the key-value secret secrets engine. |
2 | Uses the provided id to retrieve the object stored at keyspace/id . |
3 | Counts the total number of entities available within the keyspace credentials defined by @Secret on Credentials . |
4 | Removes the key for the given object from Vault. |
Object to Vault JSON Mapping
Vault repositories store objects in Vault using JSON as interchange format.
Object mapping between JSON and the entity is done by VaultConverter
The converter reads and writes SecretDocument
that contains the body from a VaultResponse
. VaultResponse
s are read from Vault and the body is deserialized by Jackson into a Map
of String
and Object
The default VaultConverter
implementation reads the Map
with nested values, List
and Map
objects and converts these to entities and vice versa.
Given the Credentials
type from the previous sections the default mapping is as follows:
"_class": "org.example.Credentials", (1)
"password": "327215", (2)
"socialSecurityNumber": "AAA-GG-SSSS",
"address": { (3)
"street": "308 Negra Arroyo Lane",
"city": "Albuquerque",
"state": "New Mexico",
"zip": "87104"
1 | The _class attribute is included on root level as well as on any nested interface or abstract types. |
2 | Simple property values are mapped by path. |
3 | Properties of complex types are mapped as nested objects. |
The @Id property must be mapped to String .
Type | Sample | Mapped Value |
Simple Type |
String firstname = "Walter"; |
"firstname": "Walter" |
Complex Type |
Address adress = new Address("308 Negra Arroyo Lane"); |
"address": { "street": "308 Negra Arroyo Lane" } |
List |
List<String> nicknames = asList("walt", "heisenberg"); |
"nicknames": ["walt", "heisenberg"] |
Map |
Map<String, Integer> atts = asMap("age", 51) |
"atts" : {"age" : 51} |
List |
List<Address> addresses = asList(new Address("308… |
"address": [{ "street": "308 Negra Arroyo Lane" }, …] |
You can customize the mapping behavior by registering a Converter
in VaultCustomConversions
Those converters can take care of converting from/to a type such as LocalDate
as well as SecretDocument
whereas the first one is suitable for converting simple properties and the last one complex types to their JSON representation.
The second option offers full control over the resulting SecretDocument
Writing objects to Vault
will delete the content and re-create the whole entry, so not mapped data will be lost.
Queries and Query Methods
Query methods allow automatic derivation of simple queries from the method name. Vault has no query engine but requires direct access of HTTP context paths. Vault query methods translate Vault’s API possibilities to queries. A query method execution lists children under a context path, applies filtering to the Id, optionally limits the Id stream with offset/limit and applies sorting after fetching the results.
List<Credentials> findByIdStartsWith(String prefix);
Query methods for Vault repositories support only queries with predicates on the @Id property.
Here’s an overview of the keywords supported for Vault.
Keyword | Sample |
Sorting and Paging
Query methods support sorting and paging by selecting in memory a sublist (offset/limit) Id’s retrieved from a Vault context path. Sorting has is not limited to a particular field, unlike query method predicates. Unpaged sorting is applied after Id filtering and all resulting secrets are fetched from Vault. This way a query method fetches only results that are also returned as part of the result.
Using paging and sorting requires secret fetching before filtering the Id’s which impacts performance. Sorting and paging guarantees to return the same result even if the natural order of Id returned by Vault changes. Therefore, all Id’s are fetched from Vault first, then sorting is applied and afterwards filtering and offset/limiting.
interface CredentialsRepository extends PagingAndSortingRepository<Credentials, String> {
List<Credentials> findTop10ByIdStartsWithOrderBySocialSecurityNumberDesc(String prefix);
List<Credentials> findByIdStarts(String prefix, Pageable pageRequest);
Optimistic Locking
Vaults key/value secrets engine version 2 can maintain versioned secrets.
Spring Vault supports versioning through a version property in the domain model that are annotated with @Version
Using optimistic locking makes sure updates are only applied to secrets with a matching version.
Therefore, the actual value of the version property is added to the update request through the cas
property.
If another operation altered the secret in the meantime, then an OptimisticLockingFailureException is thrown and the secret isn’t updated.
Version properties must be numeric properties such as int
or long
and map to the cas
property when updating secrets.
@Secret
class VersionedCredentials {
@Id String id;
@Version int version;
String password;
Address address;
The following example shows these features:
VersionedCredentialsRepository repo = …;
VersionedCredentials credentials = repo.findById("sample-credentials").get(); (1)
VersionedCredentials concurrent = repo.findById("sample-credentials").get(); (2)
credentials.setPassword("something-else");
repos.save(credentials); (3)
concurrent.setPassword("concurrent change");
repos.save(concurrent); // throws OptimisticLockingFailureException (4)
1 | Obtain a secret by its Id sample-credentials . |
2 | Obtain a second instance of the secret by its Id sample-credentials . |
3 | Update the secret and let Vault increment the version. |
4 | Update the second instance that uses the previous version.
The operation fails with an OptimisticLockingFailureException as the version was incremented in Vault in the meantime. |
When deleting versioned secrets, delete by Id deletes the most recent secret. Delete by entity deletes the secret at the provided version. |
Accessing versioned secrets
Key/Value version 2 secrets engine maintains versions of secrets that can be accessed by implementing RevisionRepository
in your Vault repository interface declaration.
Revision repositories define lookup methods to obtain revisions for a particular identifier.
Identifiers must be String
RevisionRepository
interface RevisionCredentialsRepository extends CrudRepository<Credentials, String>,
RevisionRepository<Credentials, String, Integer> (1)
1 | The first type parameter (Credentials ) denotes the entity type, the second (String ) denotes the type of the id property, and the last one (Integer ) is the type of the revision number. Vault supports only String identifiers and Integer revision numbers. |
Usage
You can now use the methods from RevisionRepository
to query the revisions of the entity, as the following example shows:
RevisionRepository
RevisionCredentialsRepository repo = …;
Revisions<Integer, Credentials> revisions = repo.findRevisions("my-secret-id");
Page<Revision<Integer, Credentials>> firstPageOfRevisions = repo.findRevisions("my-secret-id", Pageable.ofSize(4));
